Old 06-03-2006, 01:35 PM   #1
gre0481
I finally have my alero back, now that i'm in the san diego area.
Was side swiped friday morning, missed the car; tagged the mirror.
So now my question is, how do I remove the inner door panel?
I've never had an issue with late models fords or GM's when replcaing speakers, but now that I approach the alero, I'm clueless.
I removed the little panel behind the inside "handle grip) removed the 2 big phillips screws, and went to pry it off with a rubber coated prybar. It just doesn't pop off. on the bottom there is an indentation, still didn't work.
What am i doing wrong?
Appreciate any help that can be given.
Sure, tease too, I feel like it's something simple that i'm just neglecting to do.
Old 06-03-2006, 02:38 PM   #2
Thrawn
Did you get the screw behind the reflector?
Old 06-03-2006, 02:41 PM   #3
Thrawn
Check this out. It's for wiring in LED's but it still details removing the door panel
Hope it helps!
http://invision.aleromod.com/index.php?showtopic=13780
Old 06-03-2006, 03:14 PM   #4
gre0481
Thats exactly what I needed! thanks.
I searched door panel but that one didn't come up.
It was the reflector I was missing.
Knew it was something simple
