Old 06-14-2006, 12:27 PM   #1
xbxradxsx
xbxradxsx's Avatar
xbxradxsx is an unknown quantity at this point
I have 2 questions about painting interior pieces. I've read the how to on it, and still wasn't sure.
On the air vents, do you completely take them apart like all the way down to each blade seperate, or just take the outer trim piece off and then pull the blade sets with the little rod connector thingy out and paint them that way?
On the radio trim piece that goes down into the little cubby hole, is it possible to get the cigarette lighter thing out without breaking something, or do you just tape up the hole?
-Red 04 Coupe, 2.2 eco, 20% tint all around, Cosmo wai, Sprint springs, both speedbuilt sway bars,18" black Enkei Ls5's -Future plans: Kyb agx's, front and rear stb's, and a lil more in the planning...
xbxradxsx is offline   Reply With Quote
Old 06-14-2006, 01:22 PM   #2
Whitetigerboi83
Whitetigerboi83's Avatar
Whitetigerboi83 is an unknown quantity at this point
Send a message via AIM to Whitetigerboi83 Send a message via MSN to Whitetigerboi83 Send a message via Yahoo to Whitetigerboi83
i havent done my vents so i dont know but the lighter should either screw out or has two clips holding it in to take it out its been a while i rememebr one of my cars it unscrewed but i think theres the clips on it
Whitetigerboi83 is offline   Reply With Quote
Old 06-14-2006, 05:10 PM   #3
you can take the lighter out just twist and pull and for the vents i took everything apart
Old 06-14-2006, 10:40 PM   #4
xbxradxsx
xbxradxsx's Avatar
Thanks, I finally got the cig. lighter part out of the piece, so I just got done painting the radio/center console/cubby hole trim pieces a little while ago. Just gotta put the clear on them.
Anyone who's done the air vents before, when painting them, do you think it would help to tape off just the very end of each blade so the paint build-up wouldn't affect movement? Any help appreciated. Thanks.
Old 06-14-2006, 11:12 PM   #5
sburke
sburke's Avatar
sburke is an unknown quantity at this point
If you ever want to be able to adjust your vents, I don't recommend it. I personally don't care about adjusting them so I'm happy with the results.
Just take them apart as much as you can and spray them all over. I only put on two coats and it made everything pretty much unable to move. Maybe someone on here knows a trick to keep them movable. Hope that helps you out. Good luck.
99 Alero 3.4l GLS - Totalled
95 Avenger ES - Sold
01 Alero 2.4l 5spd - Sold
06 Mazdaspeed 6 - Current Vehicle
sburke is offline   Reply With Quote
Old 06-15-2006, 12:15 AM   #6
FartCannonAlero
prolly stupid but after you paint it...wiggle it around so that its not stuck in one position..then spray again and wiggle them again...hell, id try it
Old 06-15-2006, 12:26 AM   #7
sburke
sburke's Avatar
I actually tried that and it just pulled it up. So i said screw it, set the vents up how I knoew I would want them and sprayed them to death.
Old 06-15-2006, 02:43 PM   #8
i took everything apart and painted it and i can still move everything
