Old 06-28-2006, 08:07 PM   #1
jimbouc2k
After installing an intake I bought...the computer is turning on all kinds of lights and the Trac Off light comes on and the transmission starts to slip..i took the intake off and put on the stock intake and the problem persists....Can anyone tell me what I have to do to correct the problem if I can do it myself or if I have to bring it somewhere to get it looked at? all help would be great...
Old 06-29-2006, 01:40 PM   #2
cmsephiroth
did you reset the computer after you installed the intake by removing the negative battery cable?
Old 06-29-2006, 01:58 PM   #3
justinusaf
justinusaf is an unknown quantity at this point
Send a message via AIM to justinusaf
make sure you dont have the Mass Airflow sensor in backwards.
Pheenz Motorsports Founder
justinusaf is offline   Reply With Quote
Old 06-29-2006, 03:02 PM   #4
ptrudel
Designated Drunk
there's only 1 sensor on the 2.4, which is in the intake tubing...
I'm baaaackk
Old 06-30-2006, 11:35 AM   #5
justinusaf
Originally posted by 2000_olds_alero+Jun 29 2006, 02:02 PM--><div class='quotetop'>QUOTE(2000_olds_alero @ Jun 29 2006, 02:02 PM)</div><div class='quotemain'><!--QuoteBegin-justinusaf@Jun 29 2006, 01:58 PM
[/b][/quote]
Ahh thanks... good to know.
Old 06-30-2006, 09:55 PM   #6
jimbouc2k
Reset the comuter and everthing is running fine now....Thanks everybody
