Old 07-16-2006, 01:20 PM   #1
aleromod101
Roaring Noise While Driving
Ok I have 18" wheels and I know that rims will give a road noise but not this load. I mean its like roaring while im driving anyone ever have this problem or what could this be.
Old 07-16-2006, 01:35 PM   #2
acold7dusta
get an alignment?
Old 07-16-2006, 03:00 PM   #3
brsexton
Bad hub?? I know thats what mine sounded like when it went bad.
2005 Honda CR-V AWD
Old 07-16-2006, 08:34 PM   #4
Coldfire
Coldfire's Avatar
Coldfire is an unknown quantity at this point
Same here goddamn it I need 10 characters
1958 Super 88 Holiday Coupe
1970 Cutlass S
2000 Alero GLS Coupe
Coldfire is offline   Reply With Quote
Old 07-16-2006, 03:36 PM   #5
SweetNLow
SweetNLow's Avatar
do you have directional tires?
joelsoundxtreme: u faggot
Old 07-16-2006, 04:03 PM   #6
AftermathAlero
It depends on the tire compound (how it was made and the brand) some brand of tires are noiser than others when they get worn in. If its a LOUD constant noise, then it might be like said a wheel hub or something with bearing. If you just put on 18's then it might be the wheel rubbing something. Could be anything. Need to give more details.
Old 07-17-2006, 01:15 AM   #7
aleromod101
Ok ive had the wheels for some time now. But no rubbing and car is alliend. Just had driver side hub replaced.
Old 07-17-2006, 08:48 AM   #8
how do you check if the hub is bad?
my front right tire makes a ton of noise... i just racked it up to the stock wheels being crap, but i'd like to double check to make sure everything is ok before i dismiss it as a possibility.
Old 07-17-2006, 01:38 PM   #9
aleromod101
usually when a hub is out it will roar while moving. I just had my passenger one replaced today also and it didnt fix my problem. So I have brand new hubs on the front. But still doing it. I dont have a clue and they are directional tires and yes there on the right way.
Old 07-17-2006, 04:24 PM   #10
sound_xtreme
sound_xtreme's Avatar
what tires? mine roar like no other, it's just the tires
Cardomain
Old 07-17-2006, 10:02 PM   #11
bdh1976
bdh1976 is an unknown quantity at this point
Sounds like you have a broken belt in one of your tires, my honda was doing the same thing. Replaced the tires and it fixed the problem.
bdh1976 is offline   Reply With Quote
Old 07-18-2006, 12:55 AM   #12
aleromod101
Brand new nitto tires on her also forgot to add.
