Closed Thread
Old 10-03-2006, 08:49 PM   #1
Digital Horsepower PCM
Ok so i have $100 to spend and im thinkin about getting the digital horsepower pcm, butttttttt is it really necessary to fill it with premium fuel all the time, or can it go without it???? and if it can, will i notice any power gains without the premium fuel??? I probably do need to fill with good gas, but i just wanted to check with people and see what they have to say.
Thank you.
billytheman1188 is offline
Old 10-03-2006, 08:53 PM   #2
bigd6983
well with the timing advancements and all the tweeks they do im pretty sure the premium is necessary because you may start pinging and knocking.....im not dead sure about this because i dont have the pcm and have never tried but im pretty sure i remember it being required....
Old 10-03-2006, 09:00 PM   #3
alerored04
alerored04's Avatar
it is a worthwhile mod. One of the better bang for the buck mods out there. I have ran 89 in mine without a problem, but that was only once when i was in the middle of nowhere and they didnt have anything better. IMO if you are too cheap to pay the extra 10c/gal you have the wrong hobby. everything has implicit costs so if you arent willing to pay dont do it. When i did put 89 in it i pretty much drove with the radio off since i was so paranoid about it causing problems i wanted to listen to it the whole time. Its not worth the couple bucks per fill to be scared for your motor the whole time. Look at it this way, 12 gal tank, the price of premium is always 10-20c more per gal than 87/89 so no matter what fuel prices are you are only paying $2.50 more per fill up if premium is 20c more. Its not that much more expensive and worth the peace of mind. Plus the DHP pcm rocks. Get it, put 91 in it, you will love it.
Just realized it was you posting about the leaking coolant and this, save your cash until you figure out where the leak is from. limg leak wouldnt enjoy a dhp on it i dont think.
My car breaks alot.
alerored04 is offline
Old 10-03-2006, 11:07 PM   #4
mrmike
mrmike's Avatar
mrmike is an unknown quantity at this point
I also remember reading that the pcm requires a 180^ thermostat. If your leak is in the lower intake manifold, you can get the new thermostat put it while they have it all apart.
mrmike is offline
Old 10-03-2006, 11:23 PM   #5
jabartram
AutoCross Alero
jabartram's Avatar
its not required, but your fans will work overtime till you get the 180, and yes premium is highly recommended, under normal driving you won't notice much but under WOT load you will get preignition, until the pcm pulls the timing back do to KR=knock retard, when that happens you lose power.
jabartram is offline
Old 10-03-2006, 11:53 PM   #6
joealmighty13
joealmighty13 is on a distinguished road
so under normal driving you dont notice as much of a difference with the DHP, but under WOT you feel it. also whats this about KR?
joealmighty13 is offline
Old 10-04-2006, 12:19 AM   #7
jabartram
AutoCross Alero
jabartram's Avatar
no, under normal driving you wont have problems preignition(knock)or(ping) but under WOT you will. KR is knock retard, when the knock sensor senses knock or ping it retards the timing to help prevent engine damage.
Old 10-04-2006, 12:41 AM   #8
alerored04
alerored04's Avatar
why "have" someone install a tstat? its easy, do it yourself. its a $20 part why pay $100 for it. He doesnt know for sure yet if it is the limg, but yes itd work to do while its apart for that.
My car breaks alot.
Old 10-04-2006, 10:04 AM   #9
Thanks for the info man, and maybe i will get it and fill with premium if its only $2.50 more a fill up, i never thought of it that way But im gonna be checking the coolant every day and see if its going down. Now if it does how am i going to be able to find out what the problem is? should i take it to the dealer? (i know they charge up the ass, but if this is a serious problem i wanna take the car to someone i can trust) and around albany there isnt many garages that i trust to work on my car. But my main question is how am i going to find out what the problem is?
Old 10-04-2006, 10:10 AM   #10
Oh and about the thermostat, now if i get that off www.pfyc.com. is that a good one? So if i dont get the thermostat the fans will work a lot more than they are supposed to? Sorry but i just dont understand fully why i need it with the DHP? Ive heard that getting a new thermostat can be bad for your car cause your messing with the engine temp, and it should be left at the temperature that its already at?? cause when people make the cars they have it set at temperatures where the car performs best.....sorry if this sounds messed up, lol i dont know if this is coming out right. But basically someone told me the engine performs best at the temperatures the oldsmobile makers made it(stock) and if u mess with the temp you will get a shorter engine life?
is this right or do i sound like a retardlol lol
Old 10-04-2006, 03:27 PM   #11
alerored04
alerored04's Avatar
that is the correct tstat, the reason you want a colder one is that the pcm advances your timing, causing the motor to run hotter. The 180* tstat will help counter act this.
My car breaks alot.
Old 10-04-2006, 03:29 PM   #12
jabartram
AutoCross Alero
jabartram's Avatar
when a motor runs cooler it creates more power, the fans are set for 180 degree t-stats at DHP, i ran a stock t-stat for 2 weeks after my DHP install my fans just ran ALOT.
Old 10-04-2006, 08:37 PM   #13
O alright, i see now. thanks for the info! I will be ordering the DHP and Tstat in a few days. Oh and where do i install the DHP????
Old 10-04-2006, 09:03 PM   #14
jackal2000
jackal2000's Avatar
OMG
in the false floor of the trunk under the spare tire.
j/k under the dash board on the driver's side. its kind of above the brake pedal.
jackal2000 is offline
Old 10-04-2006, 09:18 PM   #15
Thank you.
It's def worth the $$$. Yes get the 180* thermostat, and use 91 or better gas. I was using 93 for a while because I only used Shell gas. Since a use my Visa instead of a gas card now, I've been going to Sunoco since they have 91 octane at the pump. The car has been running much better on 91 than 93. Once I put 94 in it and it didn't like it at all.
What grade to use really depends on what your car is programed to run on. With the PCM upgrade, the car it programmed to run on 91 or better, so it's in your best interset to run 91 or better.
A guy in work got bad advice from another guy and was told "yeah you can run 87 in your Navigator" It says right on the fuel door to run premium fuel only. It ran fine for a while, then the MPG dropped dramaticly, and it ran rough. Then a day or 2 later he got an SES light. It was pinging like crazy!! I told him to run the 93 in it again, and the light went out after about 2 weeks (2 tanks)
Redog is offline
Old 10-04-2006, 10:11 PM   #16
Originally Posted by jackal2000 View Post
OMG
Lmao, yea i figured it would be around there, just wanna check
And redog thanks for the info on the gas, i will probably fill with 91.
I cant wait to get this, i hope its worth the money
Old 10-04-2006, 10:17 PM   #17
wtf, i was reading the installation directions on the thermostat, it seems like its a pain in the ass to install. But the directions were weird, idk, how long is this installation gonna take!? for a little thermostat!
Old 10-04-2006, 11:14 PM   #18
jabartram
AutoCross Alero
jabartram's Avatar
if you have any mechanical ability at all, it will only take about an hour. its only 2 bolts and the radiator hose and a small coolant bypass tube.
Old 10-05-2006, 12:10 AM   #19
Headstrong2740
Headstrong2740's Avatar
Headstrong2740 is an unknown quantity at this point
Send a message via AIM to Headstrong2740 Send a message via MSN to Headstrong2740 Send a message via Yahoo to Headstrong2740
Hey....i was reading all this...... can some one tell me the link to the PCM site you were talking about. Id like to look into that as well. Sounds like it might be soemthing to keep in mind.
backslide
"Dude..cuming on my mom is one thing, but banging your grandmother and her two roommates is like.....legandary!"
http://www.cardomain.com/ride/2589855
Headstrong2740 is offline
Old 10-05-2006, 01:48 AM   #20
alerored04
alerored04's Avatar
www.pfyc.com. billy the tsat is not hard at all. Right underneath the TB, and you will be very happy with it. I loved mine. More now that Germ got his hands on it. lol.
My car breaks alot.
Closed Thread
