Old 10-12-2006, 06:15 PM   #1
aleromod101
Crankshaft Position Sensor
OK I have kinda posted this already. But im getting a P0336 code and its a CPS code. I have a new motor and have replaced both sensors. I would just like to know everything that could make this code come on.
Old 10-12-2006, 06:37 PM   #2
jackal2000
jackal2000's Avatar
try reflashing the whole PCM.
Old 10-12-2006, 06:53 PM   #3
aleromod101
well heres the thing i ordered a pcm of pyfc.com 2 days ago
Old 10-12-2006, 07:21 PM   #4
aleromod101
would the light be on if the crank was damaged
Old 10-13-2006, 08:54 AM   #5
aleromod101
bump bump
Old 10-18-2006, 10:10 PM   #6
Frank3
According to my FSM, P0336 is set when the ratio of 24x reference pulses to 3x reference pulses received by the PCM is incorrect when the engine is running and 3x pulses are being received by the PCM for a minumum of 3 seconds.
Possible fixes/trouble souces are:
  • Incorrect harness routing near the secondary ignition components
  • Ignition Coil arcing to the wiring harness or ignition control module (check ignition coils for cracks, carbon tracking, or other signs of damage)
  • Secondary ignition wires arcing to the wiring harness
BTW - P0336 = 24X Reference Signal Circuit
Good Luck - hopefully it is one of these....
Old 10-18-2006, 11:05 PM   #7
alerored04
alerored04's Avatar
id email dhp and ask them. Was it doing it before you installed the dhp?
My car breaks alot.
Old 10-18-2006, 11:23 PM   #8
jackal2000
jackal2000's Avatar
it has nothing to do with the dhp pcm. he hasnt even received/installed it yet. lol
Old 10-18-2006, 11:39 PM   #9
alerored04
alerored04's Avatar
oh, oops. lol, might wanna get that fixed b4 the dhp goes in then. Maybe haha.
My car breaks alot.
Old 10-19-2006, 03:17 AM   #10
You didn't recently install an underdrive pulley did you? Did you check if the reluctor was still inside the crank pulley for the sensor?
Old 10-19-2006, 12:30 PM   #11
aleromod101
Nope no underdrive pulley its all stock in the bay. But i think we have fixed the problem. The wire harness to the sensor was melted. Changed the harness and boom its alll fixed.
