Old 11-03-2006, 06:04 PM   #1
tcreek11
tcreek11's Avatar
tcreek11 is an unknown quantity at this point
Send a message via AIM to tcreek11
mass air flow sensor problems
well i purchased a mass air flow sensor and installed it and when i started my car the lights kept flickering and the car ran like shit is there any reason this could happen.
tcreek11 is offline   Reply With Quote
Old 11-03-2006, 06:06 PM   #2
Is it in backwards?
Old 11-03-2006, 06:13 PM   #3
tcreek11
tcreek11's Avatar
no it is not i checked that becaue of another thread
Old 11-03-2006, 06:17 PM   #4
tcreek11
tcreek11's Avatar
its only when it is idleing because i took a trip around the block and it was running fine once i got it up to speed it was just right when i turn it on. but i dont think it should be doing it period.
Old 11-03-2006, 06:34 PM   #5
Hmmm?
Is the connection tight? Are the wires inside the MAF damaged or bent?
The MAF uses a "hot Wire" tech.
Maybe this will help you understand better and pinpoint the problem. The MAF measures the humidity and volume of air going into the motor.
http://www.kemparts.com/TechTalk/tt06.asp
You said you bought a new one, maybe it's bad, or the wrong size for the car
Old 12-22-2007, 04:13 AM   #6
did u buy the one for the yr of your alero or did u but the corvette one or something and ur in lexgtion? im in the ville
Old 12-22-2007, 09:07 AM   #7
CBLOHM3400
Trying To Help
CBLOHM3400's Avatar
CBLOHM3400 is on a distinguished road
Send a message via Yahoo to CBLOHM3400
Did You Tighten Up The Clamps That Hold It All Together???
03 OLDS ALERO
CBLOHM3400 is offline   Reply With Quote
