Old 01-07-2007, 03:36 PM   #1
shiny alero
shiny alero's Avatar
shiny alero is on a distinguished road
Send a message via AIM to shiny alero
body kit bolt up
my body kit will be here tuesday and i want to put it on untill i can afford to have it painted in the spring..but i see there are problems with fitment? can i simply bolt my kit on (kombat) like the stock bumpers and rockers? i guess my quistion is i dont understand what anyone means by fitemnt
shiny alero is offline   Reply With Quote
Old 01-07-2007, 03:49 PM   #2
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
Fitment issues are when the kit doesn't bolt up in the exact same pattern as the stock bumper. With the AAS upper part being chopped off an Al, it should bolt right up (in theory) but there have been cases when it hasn't. If problems arise, bite the bullet and have it shop-installed
More importantly, IMO, I wouldn't put on the kit unless you plan on getting it painted in a week, two tops. At least it would give people the idea that you're going right back a LITTLE bit later to get it finished. Any longer than that and you become the Douche who rides around with a gay un-painted bodykit
CiscoPath is offline   Reply With Quote
Old 01-07-2007, 03:53 PM   #3
shiny alero
lol i see them all the time, im supposed to be getting a good deal on the paint "i work at a dealership and im good with the body shop manager" but who knows how much that is gonna be. i can do about 200 but im thinking its gonna be about 400....how long should i expect it to take if i install myself? and what tools will i need?
Old 01-07-2007, 04:19 PM   #4
koruptid
koruptid's Avatar
koruptid is an unknown quantity at this point
Send a message via AIM to koruptid
my aas kit fit fine bolted right up just like the stockers
koruptid is offline   Reply With Quote
Old 01-07-2007, 05:06 PM   #5
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
tools you'll need for bumpers:
flathead screwdriver (for the little plastic clips)
socket wrench
not sure about the rockers. I never had to deal with them.
and fitment means exactly what you think it means. good fitment means the kit fits the way it's supposed to. if you have bad fitment, you will need an experienced person to alter it to fit well. Preferably a professional.
Old 01-07-2007, 05:47 PM   #6
ppgnut
if your asking then don`t do it
my professional advice to you let the shop do let them make it fit!
Old 01-07-2007, 06:43 PM   #7
shiny alero
i think ill try it, if i start having problems itll go back together, im usualy pretty good at figureing stuff out thanks for all the help guys! ill post pics soon as i can
Old 01-07-2007, 06:55 PM   #8
2fst4u
[boosted 2.4L]
2fst4u's Avatar
it's not hard at all. mounting the front is a matter of drilling two holes on top for christmas tree clips, drilling two holes on each side at the fenders for bolts. Then the back is drilling a couple holes around the inner tire well, and also more christmas tree clips along ledge of the trunk. be sure to paint your back bumper bar black as it will be seen. also, make sure you use the styrofoam under the bumper cover on the front. don't use it in the back tho. the sideskirts need screwed into each end, and you'll have to remove a little bit of material on the inside of the fiberglass skirt. screws go in the ends, and apply some panel bond underneath when the go on for good.(urethane adhesive works pretty good for this)
hope that helps.
Old 01-07-2007, 07:25 PM   #9
ppgnut
ok dude he is having trouble already and i don`t think needs your i guess you can say unprofessional advice on a install, like your talking about panle bond??? you forgot to mention that he will need to buy the material and the gun to apply the panel bond?? you also forgot to mention that panle bond need clean metal to proplery bond to a surface for a inseperable bond did you also mention that panel bond is corrosive resistant??
if he would use a urathene are you refering to window urathene?? i don`t suggest using that product for install, or even if he used a plastic repair product for install would not work properly as well
the energy absorber or the styrofoam as you call it can be shaped to fit ya know the energy absorber actually has a purpose
the re-bar or as you call it the back bumper bar is black so why would he paint it again??
what iam trying to do i clear up in correct terms and try to l********* you in the right direction
and the correct term is ROCKER PANLE MOLDINGS
Old 01-07-2007, 07:29 PM   #10
whiteliquid
Defeat < Giving Up
whiteliquid's Avatar
whiteliquid is an unknown quantity at this point
Send a message via MSN to whiteliquid Send a message via Yahoo to whiteliquid
Mine is sitting under my house all wrapped up in plastic wrap and boxed up. Im not gonna put mine on til this summer because i dont have the money to paint it or get rims. But this summer she is going to be beautiful .I'll be making close to 800 a week, so it'll be no problem.
But I am doing the install all by myself . The main thing is make sure you have a partner helping you. That always makes it 100 times easier. And take it slow
WhiteLiquid
whiteliquid is offline   Reply With Quote
Old 01-07-2007, 07:33 PM   #11
whiteliquid
Defeat < Giving Up
It's Side skirts well if you go by what the people that actually produce them call them, and the back bumper is not black...its a greyish color. Dont get so "professional" he's not going to understand body work jargon if he doesnt even know what fitment means. IM not tryin to argue with you because you have many years of experience over me....but chill a little. Just laugh if he messes up, and then tell him all this stuff.
WhiteLiquid
Old 01-07-2007, 07:36 PM   #12
burg03
let a shop do it
Old 01-07-2007, 07:40 PM   #13
Mr_White
Mile High Club
Mr_White's Avatar
Mr_White is an unknown quantity at this point
mine was white but I painted it black
http://www.aleromod.com/forums/image.php?type=sigpic&userid=1988&dateline=1166644  267
Mr_White is offline   Reply With Quote
Old 01-07-2007, 07:43 PM   #14
burg03
Is that the food section,or the metro section
Old 01-07-2007, 08:45 PM   #15
ppgnut
ROCKER PANLE MOLDINGS one more time is the correct term, and every n-body i have fixed the RE-BAR was black, and yes i will correct people when the incorrect name for a part is given
one more time let a shop do it
Old 01-07-2007, 08:57 PM   #16
Oldsmowimp
double side tape that bitch on. If it falls off, who cares it'l look better.
Old 01-07-2007, 09:00 PM   #17
whiteliquid
Defeat < Giving Up
Dude how can you call them rocker panel moldings when AAS the company that CREATED them calls them side skirts. Thats like telling a parent what their kids name "really" is .
WhiteLiquid
Old 01-07-2007, 09:01 PM   #18
whiteliquid
Defeat < Giving Up
HAHA or you could just put some wood screws and duck tape like i see alot of people around here do....no lie
WhiteLiquid
Old 01-07-2007, 10:08 PM   #19
Someone's not a big fan of the AAS kit? hahaha
Old 01-08-2007, 12:45 AM   #20
I think GM created them, AAS just made some aftermarket ones. and in the GM service manual they are defined as rocker panel moulding.
Calling them side skirts is like calling your wheels "rims".
