Old 02-20-2007, 01:17 PM   #1
AsianAlero
AsianAlero is on a distinguished road
Send a message via AIM to AsianAlero
Cool Dhp Pcm???
Ok so I have a few questions. Is PFYC.com the best place to purchase this PCM mod? Its 100 after u return the core.
Now I only have a WAI with a custom cold air box. Something I made from home depot. I don't plan on getting an exhaust. Maybe the 180 thermostat and that it. Would I still get the performance from the PCM??? Is this recommended?
AsianAlero is offline   Reply With Quote
Old 02-20-2007, 01:27 PM   #2
alerored04
alerored04's Avatar
you will gain a few horse. the best features are the improvements to the transmission setup. I have one, its a nice mod but remember that you need to switch to 91 octane after you install the pcm, thats a detterent to some people. It will work fine with the mods you have. But next time try the search feature, this has been discussed lots around here.
My car breaks alot.
Old 02-20-2007, 01:38 PM   #3
AsianAlero
Thanks so did u have to go get a case learn from the dealer afterwards I would like to avoid this procedure if possible? Or is it something you just have to get lucky with? Cuz the dealer that svcs olds around me is a cadillac dealer and I'm sure they are gonna charge me people there are so damn snoody when u come in with an olds like the look down on you...lol
Old 02-20-2007, 01:40 PM   #4
alerored04
alerored04's Avatar
i had to get one, it was only like $30. No big deal. Just make sure they do only the learn and not a reflash cause that will put the whole pcm you just bought back to stock.
My car breaks alot.
Old 02-20-2007, 01:45 PM   #5
AsianAlero
Sorry for all these ?'s so I won't get the iimprovements til I do the learn?? And I will be able to drive the car right? What is the learns purpose?
Old 02-20-2007, 05:14 PM   #6
jackal2000
jackal2000's Avatar
And is it located on the right of the gas pedal?
located to the left of the brake pedal. up under the dash. my DHP pcm was plug and play so you may get lucky like i did.
Old 02-20-2007, 05:16 PM   #7
shackney
shackney's Avatar
shackney is an unknown quantity at this point
Send a message via AIM to shackney
do u have to get new exhaust or does stock work fine?
1999 Oldsmobile alero 3400 sfi
shackney is offline   Reply With Quote
Old 02-20-2007, 05:19 PM   #8
jackal2000
jackal2000's Avatar
the less mods you have the less gain you will see from this PCM. the PCM mod is somewhat of a multiplier to your other supporting mods.
Old 02-20-2007, 05:23 PM   #9
shackney
shackney's Avatar
cause i was thinking bout gettin this and then in couple more weeks doin the exhaust but wanted to make sure it will run fine on stock til i get my exhaust done
Old 02-20-2007, 05:45 PM   #10
jackal2000
jackal2000's Avatar
it'll run fine, most likely it will run rich which equals a drop in MPG but it will be slight.
Old 02-20-2007, 05:47 PM   #11
shackney
shackney's Avatar
i already get 14-16 mpg anyways for some reason and my o2's are good...
Old 02-20-2007, 09:50 PM   #12
Jferg2223
Jferg2223's Avatar
Jferg2223 is on a distinguished road
i do believe they tell you how to do the case learn yourself do they not? i guess its the security relearn procedure i'm talking about. i have the pcm it was given to me from my buddy who had a grand am so i dont know what the case learn actually is
3400 V6
MSD Coils - NGK Iridium Plugs - Taylor Wires - 62mm RSM Throttle Body - DHP PCM- 180 Stat - TPS Enhancer - Custom 3" CAI - Thunderbolt Spin Cat no resonator - Dynomax Dual exhaust w/ Borla Tips- Cleared Corners/Black Bezels
Jferg2223 is offline   Reply With Quote
Old 02-20-2007, 10:03 PM   #13
Frostbite545
Frostbite545's Avatar
Frostbite545 is an unknown quantity at this point
Send a message via AIM to Frostbite545
The Security Relearn is a relatively simple procedure that takes around 15 to 25 minutes, so that the car will actually start. Apparently it thinks you are stealing it or something when you replace the PCM.
The CASE learn is something that can be done by the dealership for a nominal fee, and should be done soon after you get the PCM, usually when your car throws a SES or Check Engine light. CASE learns just makes sure everything is correct with the crank case positioning. In my case as well as Jackals, there was no CASE learn required, so we were fortunate .
Yeah thats about it, and they have been discussed a lot, I did a good bit of research before getting mine, its worth it imo.
- (2000 GL) 14.748 @ 93.04
- Doctor Speed Cold Air Intake
- DHP PCM / 180* Tstat
- General Exclaim UHP Tires
- 2 1/2" Pacesetter Exhaust
- S&S Headers
Frostbite545 is offline   Reply With Quote
Old 02-20-2007, 11:09 PM   #14
alerored04
alerored04's Avatar
shackney i ran a dhp v 1.0 for almost a year without exhaust. Then a friend with powertunr pushed it even further on the stock exhaust. Its not stock any more though. I ended up getting better milage. It will be fine.
My car breaks alot.
Old 02-27-2007, 11:13 PM   #15
Jferg2223
Jferg2223's Avatar
Mine is throwing a SES light but i figured it was O2 sensors reading rich, so i should get a case learn if its throwing the code and what could happen if a dont get the learn
3400 V6
Old 02-27-2007, 11:27 PM   #16
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
^^Most people who get the code generally just take it to the dealership and get the Relearn. I don't know of anyone who didn't get it just to SEE what would happen. I can tell you that without the Relearn, the speed limiter is removed and the fans do stay on after the car is turned off for cooldown, so some features are automatic. But from what I believe, the Relearn is for the Crankcase Position which controls the timing advance i.e. spark/fuel ignition. With the fuel map being advanced more by the new PCM but not have the Relearn adjusted to it will make it run rich..............or lean. One of them, I dunno.
On the other hand, the SES code is thrown whenever the PCM is removed, whether replacing it with an upgrade or removing the stock one for God knows what and putting it back in. It's a safety feature. On the latter, I believe the car would still run fine with the stock. Can't say the same with the upgrade though with the changes made to the map, so just play it safe and get it cleared.
CiscoPath is offline   Reply With Quote
Old 02-28-2007, 10:39 AM   #17
Jferg2223
Jferg2223's Avatar
hittin the dealership today for 40 bucks
3400 V6
Old 02-28-2007, 12:43 PM   #18
the car will not start until you do the security relearn, so yes you will not see any gains until the relearn is done.
Old 02-28-2007, 03:40 PM   #19
CiscoPath
CiscoPath's Avatar
-edit-
Old 02-28-2007, 03:46 PM   #20
The only things you NEED for the PCM is the 180* Thromo, and 91 or better octane.
But like it's been said, the less mods you have, the less gain you'll get from this
