Prev Previous Post   Next Post Next
Old 03-13-2007, 04:16 AM   #1
Vinalero
Vinalero's Avatar
Yeah, Bearings again...
Ok now my three lights come on as soon as I start the car. (SVS, ABS, Track off)
I'm not hearing any noise from any wheels and the car seems to be driving correctly. I know those 3 lights most likely means a bearing is going. Since I cant hear some rubbing noise from the bearing, could it be something else? Also, how can the 3 lights come on even if I haven't rolled an inch with the car? I thought maybe a sensor plug is loose on one of the wheels.
Any Ideas?
Also, what brand of hubs would you recommend? Is it hard to change?
