Old 04-12-2007, 09:36 AM   #1
DaRockwilder
DaRockwilder's Avatar
DaRockwilder is on a distinguished road
Spoiler Removal?
I was just curious if theres any glue or a sealant holding the spoiler to the trunklid? Is it just a gasket? I want to pull my spoiler off just to see how it would look without it, but I'm not going to if I need to re-seal the spoiler to the trunk.
Thanks!
DaRockwilder is offline   Reply With Quote
Old 04-12-2007, 09:44 AM   #2
whiteliquid
Defeat < Giving Up
whiteliquid's Avatar
whiteliquid is an unknown quantity at this point
Send a message via MSN to whiteliquid Send a message via Yahoo to whiteliquid
there is some double sided foam holding it down and it helps to keep the water out too.
WhiteLiquid
whiteliquid is offline   Reply With Quote
Old 04-12-2007, 09:57 AM   #3
DaRockwilder
OK! I'll probably hold off removing it then until I do a few other things. Thanks!
Old 04-12-2007, 10:01 AM   #4
CaRcRaZy
CaRcRaZy's Avatar
CaRcRaZy is on a distinguished road
hey are there any screws holding the spoiler on? If not can i just buff off the foam and have a clean look?
CaRcRaZy is offline   Reply With Quote
Old 04-12-2007, 10:02 AM   #5
DaRockwilder
Yeah there are two bolts on the underside of the trunklid. Per post.
Old 04-12-2007, 10:25 AM   #6
CaRcRaZy
CaRcRaZy's Avatar
Do you know what i would need to do to make the trunk lid solid if i took the spoiler off? Where i live every alero has the spoiler, i don't like that i look the same as them, and i personally think it looks better without the spoiler.
Old 04-12-2007, 10:27 AM   #7
DaRockwilder
A mig welder would be a good start...
Old 04-12-2007, 01:33 PM   #8
whiteliquid
Defeat < Giving Up
I would look for one at a junk yard that didnt have a spoiler even if its not the right color....trade them for yours. Then take the new one to get painted. It will be cheaper than having someone weld the holes in and then paint it.
painting it will run u around 200
WhiteLiquid
Old 04-17-2007, 01:01 PM   #9
bnight04
bnight04's Avatar
bnight04 is an unknown quantity at this point
Send a message via AIM to bnight04
fuuuuuuuuuuuuuu*k that just rattle can it, then clearcoat it.
2004 40th aniv. mustang
2006 kawasaki ninja
bnight04 is offline   Reply With Quote
Old 04-17-2007, 02:46 PM   #10
Xtrm
Xtrm's Avatar
Xtrm is on a distinguished road
Send a message via MSN to Xtrm
gotta be pretty damn good with a spray can not to get any orange peel in it....paint gun is the only way to go
Xtrm is offline   Reply With Quote
Old 04-17-2007, 03:19 PM   #11
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
there's plenty of orange peel from the factory...but you'd have to be really good at painting in general to get it to match the factory peel.
IMO, if you can afford it (in time and money) just get the whole trunk lid done at once instead of a paint-patch job.
Old 04-17-2007, 03:43 PM   #12
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
theres 2 bolts holdin it down with double sided 3M tape, I just used a flat flat screw driver to pry it off. I used my nail and some goo-gone to get the rest of it off.
Old 04-17-2007, 05:35 PM   #13
Xtrm
Xtrm's Avatar
i understand there is alot of orange peel from teh factory...and its almost impossible to match factory orage peel, i should know i work in a body shop. But i was just sayin why spray it with a spray can and make it look worse than using a gun.
But i agree on buying a new trunk lid, would be much easier to do.
Old 04-17-2007, 05:46 PM   #14
AlbinoMonkeyRat
Let's Play Army!
ahh ok. you haven't made many posts to read here, so I didn't know your experience.
