Old 04-17-2007, 08:54 PM   #1
shiny alero
shiny alero's Avatar
shiny alero is on a distinguished road
Send a message via AIM to shiny alero
should it shift so late"?
recently it seems as if my tranny is messed up. if im at a lite and i gun it. i hit 6500 to 7000 RPM befor it finally shifts. is this right? also its as if it kicks into gear...hard to explain but for the most part that shift point is concerning me...i dont have any tranny lights or check lights on...just seems differant.
shiny alero is offline   Reply With Quote
Old 04-17-2007, 08:56 PM   #2
yeah it should shift at 6200, shouldn't it?
Old 04-17-2007, 09:26 PM   #3
SHould shift long before that
TPS sensor?
Old 04-17-2007, 09:34 PM   #4
shiny alero
would a lite come on?
Old 04-17-2007, 09:36 PM   #5
Maybe not.
My friend is having the same problem with his Chevy truck right now. He thinks the header burned thru some wires
Old 04-18-2007, 09:17 AM   #6
ptrudel
Designated Drunk
my sister's 2002 cavalier z24 w/ 2.2ecotec will hold its gear til about 6400rpm...its the only auto i dont mind driving
I'm baaaackk
Old 04-18-2007, 02:32 PM   #7
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
i think it is like 6,700RPM before the rev limiter kicks in, i normally let it rev right up to 6,500 before shifting. So yea, your fine. its a 4 banger, they love the high revs.
steve-o is offline   Reply With Quote
Old 04-19-2007, 09:27 PM   #8
Spilner521
Boost Guru
Spilner521's Avatar
When you're at WOT, it's supposed to shift at redline, which is 6500 rpm for 2.4's and Eco's. It only shifts long before that when you're just cruising. Shift points all depend on how much throttle you give it. The further you push the pedal the later it's going to shift. What you're describing is completely normal.
