Old 05-13-2007, 10:52 PM   #1
tonyboi261
tonyboi261's Avatar
tonyboi261 is on a distinguished road
key ignition problem
does anyone else have to like wiggle the key so the car can start?? i was just wondering if anyone else had this problem...
99 white alero 4 door-R.I.P you will be missed
92 opal green civic 4 door-h22 turbo running mid 11s
"i might not look like much but im a pro at pretending to be a ninja!"
tonyboi261 is offline   Reply With Quote
Old 05-13-2007, 11:43 PM   #2
yeh.. like it wont turn unles u jiggle it?
yeh i though it was my cylinder but it was actually my key. about a year ago the 99's key was wearing down so bad it wasnt being sensed the same or whatever. New key? all fixed. Except that its a chevy key.. ew.. no more olds dealerships means no more new olds keys!
Old 05-13-2007, 11:45 PM   #3
SIUlero
SIUlero's Avatar
SIUlero is on a distinguished road
I haven't had this problem, but I've heard it's common on GM's with the dash mounted key cylinder. The only fix is to replace it. To prevent it from happening again, keep your keychain light. I have my valet key on a ring by itself (and a plastic bottle opener, so it's easier to find in my pocket) and just use that for driving the car. I keep my master key with all the rest of my keys on another chain. It serves another purpose, too, by making it nearly impossible to lock my keys in my car
SIUlero
'01 Alero GL
'72 Cutlass Supreme
http://www.cardomain.com/id/CrazyOldsGuy
SIUlero is offline   Reply With Quote
Old 05-14-2007, 11:42 AM   #4
I've been having this problem too
Old 05-14-2007, 08:16 PM   #5
tonyboi261
tonyboi261's Avatar
i found a cheap and easy fix to this ^^ all u have to do is get it to turn on then mark the length with a marker or something and wat i did is tied string around it......works like a charm
i heard the reason it did this was that at the end there is lock pin thing that if the key is too far in or not far in at all it will not let u turn the key
Old 07-08-2007, 03:27 PM   #6
Branson
Branson's Avatar
Branson is on a distinguished road
I Have Had A Similar Problem With My Junk Too
One Day When I Was Turning My Car Off It Somehow Got Stuck In Acc. I Wont Go Any Further And The Lights Stay On... What Is Up With It Now..how Can I Fix It..
Branson is offline   Reply With Quote
Old 07-08-2007, 04:00 PM   #7
NjRef511
...did you have the car in park?
Old 07-08-2007, 05:24 PM   #8
Branson
Branson's Avatar
acutally i dont think so beacause i was putting in my radio and i had it in first to remove the plastic ... but now it is in park and it still wont go into "off"
Old 07-08-2007, 05:27 PM   #9
Branson
Branson's Avatar
also it can go forward and start without a key . it just wont go into "OFF"
Old 07-08-2007, 07:42 PM   #10
the button on your shifter is being pressed down, my guess if you have an aftermarket shifter and it is not installed correctly. if it is applying pressure to the button it will not allow you to take the key out of the ignition because the car doesn't think its in park
Old 07-09-2007, 09:47 AM   #11
Branson
Branson's Avatar
thats was it...thanks man ... i guess ill just chunk my shifter i got and put the old one back on...Thanks again bro
