Old 05-14-2007, 01:14 AM   #1
DaRockwilder
DaRockwilder's Avatar
DaRockwilder is on a distinguished road
Rear Hubs
Can anyone tell me if the rear hubs are the same between a disc brake rear and a drum brake rear? My rear hubs have electrical connections in them for the ABS, but there are no wires, just a plug to keep the contacts clean I guess.
If they're the same I don't have to get some from a junkyard when I swap from drums to discs.
Thanks!
DaRockwilder is offline   Reply With Quote
Old 05-14-2007, 01:16 PM   #2
the ACDelco parts vehicle list shows the same hub for both of then as long as they're ABS. (part R20-03). You do need the whole knuckle for the caliper mounting however. It would be easier just to pull the whole assembly off the car in one piece so you're not taking it all apart at the yard.
Old 05-14-2007, 08:47 PM   #3
DaRockwilder
Ok. I'm fairly certain I've got the ABS hubs. None of the pick n' pull yards around have Aleros. so I have to go to one of those "Automotive recyclers" where they charge you almost new price for stuff.
All i really want from the junkyard are the knuckles, park brake cables, and caliper brackets. Everything else I should probably buy new.
Old 05-15-2007, 01:18 AM   #4
Even if you don't have ABS, the hubs should still work. It's just that all the rear disc cars have ABS.
Old 05-15-2007, 09:00 AM   #5
DaRockwilder
Ok, cool.
How does the parking brake work on a disc brake setup? My car has drums, and I know I need the cables when I swap, but I really have no clue how the e-brake works on the discs. Something about a "drum in hat" comes to mind.
Thanks!
Old 05-15-2007, 12:46 PM   #6
It's basically like a little drum with a one-piece shoe inside the middle of the rotor.
Old 05-15-2007, 06:48 PM   #7
DaRockwilder
OK, thats kinda what I thought, by the name. I guess I should get just a whole setup from the junkyard and change whatever I don't feel comfortable using.
