Old 05-16-2007, 09:14 AM   #1
rottnme
rottnme is an unknown quantity at this point
Tranny Slip
I know that this is a relatively frequent topic and I did a search and read through the posts concerning transmission slip and have yet to come up with anything that seems to be a common fix. From what I can see, a lot of the problems (like mine) start prior to a fluid change.
My question is what has worked to fix the problem? (adding fliud, tourque converter, conditioners(hasn't worked for me yet), etc.)
Thanks
rottnme is offline   Reply With Quote
Old 05-16-2007, 10:55 AM   #2
TheMeaningOfLife
TheMeaningOfLife's Avatar
Have the fluid replaced and see what happens. Its not all that expensive and its probably a good idea anyway.
Old 05-16-2007, 11:34 AM   #3
rottnme
Had it replaced. First at 100k service and it hasn't been the same since. It was changed again at 102.5k after the slippage started, then I had a trasmission guy look at it and no problems were found. Now with less then 500 miles since last changed it is starting to slip again badly. Same story as before, and same as many other posts I've read... fine when cold, slips after getting warmed up. I just want to know how to get it fixed before I need a new trans.
