Old 05-18-2007, 03:27 PM   #1
lovefrom1977
lovefrom1977 is on a distinguished road
help with removing door pannel?
Ok i wanted to remove the front passenger door pannel on my car because i needed to see the lock because someone broke into my car. i know you have to unscrew the screws under the handle and then the reflector. but how do i get it off? like theres clips too and stuff someone said. also are the two metal rivits on the bottom holding the door on too or what do i do with them?
lovefrom1977 is offline   Reply With Quote
Old 05-18-2007, 05:51 PM   #2
PULL!! start at the bottom and pull untill it pops off all the way around then u lift it stright up and out of the thing by the window(name?). then u gotta unhook the wires from the switches. it really easy i've done it a few times. a lot eaiser than the rear doors. O yea pop off the tweeter pod first.
Old 05-18-2007, 06:09 PM   #3
jackal2000
jackal2000's Avatar
yea, use a screw driver to pry it away from the door and get it started. then just pull straight out. dont be afraid to put some muscle into it.
Old 05-18-2007, 07:05 PM   #4
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
use force but at the same time be gentle cause if those clips break, your hooped!!
Old 05-18-2007, 07:12 PM   #5
^ not too bad if you break them though. i only have like 2-3 clips left in each door. the 3 screws hold it on pretty well...
Old 05-19-2007, 02:05 PM   #6
lovefrom1977
ok thanks you guys. do i have to do anything with the metal rivets on the bottom of the door?
so i just unscrew the screws and take the tweeter pod out and then pull starting at the bottom?
Old 05-19-2007, 04:06 PM   #7
thats all there is to it.
