Old 05-23-2007, 01:39 PM   #1
dbailey
dbailey is an unknown quantity at this point
Question Radiator Leak????
Guys I am having a coolant leak right where the small hose that comes from the small tank connects to the radiator. I replaced both of those small hoses and have cranked the clamps down tight and it STILL Leaks there at the radiator. Has anyone had top replace the radiator? I'm afraid the nipple where the hose attaches may be cracked or something. Haven't taken the hose off to check yet. It really only seems to leak the most right after I refill the small tank back up. It leaks down and then almost stops leaking. That's kinda weird because since it's under pressure you'd think it would leak all the time. Any suggestions?
dbailey is offline   Reply With Quote
Old 05-27-2007, 03:54 PM   #2
dbailey
BUMP Any ideas anybody??????
Old 05-27-2007, 06:58 PM   #3
greenbastard
greenbastard's Avatar
greenbastard is an unknown quantity at this point
gasket maker the eff out of it!!!
01 Alero GX 3400 swapped
v8 swapped 84 s10
greenbastard is offline   Reply With Quote
Old 05-29-2007, 02:22 PM   #4
dbailey
Hmmmm...gasket maker? I may just try that! Thanks. Any other ideas guys????
