Old 06-04-2007, 09:24 PM   #1
bassboss
bassboss is an unknown quantity at this point
Exclamation Hhheeelllpppp!!!!!
Hey Guy's, It's been a while since I've been on here. Good to see lots of new peeps!
Anyways, I have a few problems with my Alero, Mostly, just IT WON'T START, and then there's the small problem of No Clutch pressure what-so-ever (Actually it has a negative pressure , as in the clutch is all the way to the floor and even when I pull it back out it slams back to the floor, )
ok on to the questions , When I try to turn over the Engine it just winds and winds and winds and ....... you get the picture. I cannot hear the fuel pump when I turn the key to the "on" position - fuel problem, I got it. OK - well I have checked the fuel pump relay, fuses and everything is good. Can anyone tell me what else to try or what can I do???? ARRRGGG........
Next Question - it's actually kind of a duh... Stupid question.....How do I bleed my master Clutch Cylinder and where the hell is it located????
Thats about it for now. I've been without the Alero since Jan. and would like to get it back. A $300 93 Sundance just don't cut it anymore.
Oh yeah it's a 2002 2.2 5spd.
Thanks peeps,
Cheers
bassboss is offline   Reply With Quote
Old 06-04-2007, 10:29 PM   #2
the fuel pump is probably bad.
Old 06-05-2007, 04:42 AM   #3
bassboss
I was Figerin that much, but how do I test it?
Old 06-05-2007, 09:32 AM   #4
AGT
AGT's Avatar
You can check your fuel pressure at the fuel rail. There is a valve off the side...wait...you have the 2.2
Anybody know where its at on the 2.2?
Old 06-05-2007, 04:18 PM   #5
bassboss
Basically, for the fuel pump prob, I want to know how to test the electrical for the fuel pump. I want to know if it is getting power to the pump (so then i know if it's the pump or not) or if it's an electrical problem that can be easily fixed.
I need to get this car back up and running. I still owe money on it.
Anyone else have the problem of the clutch loosing pressure. This is my second Alero and I've had the same Clutch problem with both of them. Never did find out what the prob was on the first one. sold it to a "Mechanic" before i was able to get it fixed.
Old 06-06-2007, 01:31 AM   #6
No idea on the clutch thing, mine does it too. the fluid level just goes down in the reservoir with no sign of leakage. Has to be either the slave or master cylinder.
