Old 06-05-2007, 11:27 PM   #1
ShortCircuit
Rough starts, Sometimes slowly dies at start. Bad gas
well i have been getting bad gas mileage and recentlu has a hard time starting up, im pretty positive that i just need some fuel injector cleaner as that would help everything im having problems with. Well ill keep u updated... untill then let me kno what ya think.
Old 06-05-2007, 11:43 PM   #2
antichrysler
perhaps a new fuel filter too
Old 10-07-2007, 08:55 PM   #3
MacsAre1
MacsAre1 is on a distinguished road
Ever get this problem fixed? I'm having similar issues. Threw in fuel injector cleaner, replaced the fuel filter, more fuel injector cleaner, none of that helps. Just wondered how you fixed it if you did.
1999 Alero GLS 3400
101000 miles
MacsAre1 is offline   Reply With Quote
Old 10-08-2007, 02:13 PM   #4
Maybe spark plugs and boots, fuel pump, or fuel sending unit, clogged injectors (could still be a problem there)....etc.
Old 10-12-2007, 01:50 AM   #5
dubbzalero
dubbzalero is an unknown quantity at this point
Send a message via AIM to dubbzalero Send a message via MSN to dubbzalero
check resistance in plugs and wires. should be around 1-4 K ohms for plugs and 9-14 k ohms for wires. just a thought
01 Olds Alero
dubbzalero is offline   Reply With Quote
Old 10-12-2007, 06:34 AM   #6
nickbain
nickbain's Avatar
nickbain is on a distinguished road
does it throw any codes? Check the EGR valve...my old one was doing this and I had the injectors cleaned and fuel filter replaced several times and it turned out to be the EGR valve.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
nickbain is offline   Reply With Quote
