Old 06-10-2007, 04:29 PM   #1
AleroGX04
AleroGX04's Avatar
AleroGX04 is an unknown quantity at this point
Send a message via MSN to AleroGX04
Led dash backlights
hello all, been awhile since i've posted here, but i got a question on the bulbs behind the dash. I know this has been in a previous thread, which i read. but when i took apart my dash, i found two different size bulbs. there were 5 194 bulbs i believe, i replaced them with the 194 leds i got, but there were like 4 or so other bulbs, smaller. any ideas on the size?
Live life a 1/4 mile at a time!!
AleroGX04 is offline   Reply With Quote
Old 06-10-2007, 04:33 PM   #2
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
you can just replace all the bulbs with LED's, doesnt have to be the 194's.
what i did was just take the original bulbs out, used LED's with resistors on them and soldered them on the "condom" and make sure the tips of the LED's were flat to difuse the light more evenly and make sure they are in the middle and not crooked or else the light will be un even.
do a little bit more searching and look through the How to section for the guide and it will tell you what to do step by step and with pics
Old 06-10-2007, 04:53 PM   #3
AleroGX04
AleroGX04's Avatar
im not big on sodering, is it possible to get the size of thos bulbs and replace without sodering??
Old 06-10-2007, 05:49 PM   #4
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
look at the pics in this thread
http://www.aleromod.com/forums/showt...ighlight=guage
is that what you are going for? if so, then its just the 6 194's you'll need to change, dont worry about the small ones
Old 06-10-2007, 06:03 PM   #5
AleroGX04
AleroGX04's Avatar
ya, thats what im goin for. thanks a lot..what are the smaller ones to then?
Old 06-10-2007, 06:40 PM   #6
the smaller ones are the lights for turning, the center shift lights, and hazard lights...
not sure about the size.. technically, you COULD replace those w/ 3mm Leds... but again, you'd need resistors.
I've thought about it... and thanks to albinomonkeyrat, i have an extra dash circuit board to play with... the only down side, is i'd have to play with which wires are hot and ground to get a good current through the system. (enter da haynes manual, but i'm kinda lazy lately. maybe a later summer project)
Old 06-11-2007, 12:46 AM   #7
AleroGX04
AleroGX04's Avatar
http://i121.photobucket.com/albums/o...0610072337.jpg
theres a pic of the dash with the led's in. seems a few are brighter or miscolored from the rest, idk if its just the pic or what.
Old 06-11-2007, 10:15 AM   #8
you didn't sand the ends of the leds flat.. thats the problem in that pic. you'll get "hot spots" of where the light is more concentrated. Sand them down, (just the curved end) and that'll go away.
http://i178.photobucket.com/albums/w...terior0019.jpg
thats mine w/ the ends sanded...
Old 06-11-2007, 09:48 PM   #9
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
yup, you just forgot to sand them down
