06-18-2007, 12:01 PM
Warning Lights Commin On For No Reason.....
So im driving down the highway lastnight and all of a sudden my CHECK ENGINE, ABS, and TRAC OFF lights come on. So I pull over thinking it just might be a loose conection on the battery....nope. I get back in the car, start it up and the lights are off. So i begin to drive again, and all three lights come back on again. Nothing seems to happen when the lights come on, performance wise. Anyone out there know the reason behind this?????
2003 Alero GLS 3.4L
06-18-2007, 12:31 PM
Hub sensor possibly
06-18-2007, 12:59 PM
MINIac
Check Engine or Service Vehicle? If it's SVS that's a pretty good clue (with the other two) that it's a hub.
06-18-2007, 01:14 PM
As stated above..
I'd put my money on the hub/wheel bearing sensors..
It will come on more and more periodically..
06-18-2007, 01:53 PM
Ya check if its a Service vehicule soon light or Service Engine soon
If its Service Vehicule --> Hub goin bad
06-18-2007, 02:12 PM
It is service engine soon...sorry about the mistake in the orginal msg. so what am i lookin at spedning to gettin that replaced if i bring it in to a shop, any idea??
2003 Alero GLS 3.4L
06-18-2007, 02:40 PM
Lol..
06-18-2007, 03:51 PM
Originally Posted by [ion] C2
Lol..
WOW i am sorry....work must be gettin to me today. lol Its SERVICE VEHICLE SOON. i was just informed that i can clean the ABS conectors and that should fix the problem. anyone recomend me doing such?
2003 Alero GLS 3.4L
06-18-2007, 03:54 PM
my dad had the same problem with his grand am, its the wheel hub going bad, or the snesor, in our case it was the hub.
06-18-2007, 04:05 PM
Southern Fly Boy returns
welcome to owning an oldsmobile
06-18-2007, 04:14 PM
so back to to my previous question....just cleaning the ABS plugs...should that maybe do the trick???
2003 Alero GLS 3.4L
06-18-2007, 04:42 PM
mine went away, just the sensors, try cleaning em
06-18-2007, 04:56 PM
ok...im most likely asking stupid questions now lol, but pls forgive me i dont know much about this kinda stuff. you tell me to clean the sensors...is this the same as what i have been saying by disconnecting the ABS and cleaning that connection? Or are the sensors soemthing completely different??
2003 Alero GLS 3.4L
06-18-2007, 05:32 PM
CHeck your connection and the wires as well just incase they are kinked or pinched
