Old 06-20-2007, 01:43 PM   #1
NibCrom
Brake Light
So I was driving home last night and I heard a ding. Looked down and my BRAKE light was on, glowing red. The light went off and then came back on again. What is that warning me of exactly? Low brake fluid?
Old 06-20-2007, 02:26 PM   #2
AGT
AGT's Avatar
Your brake light on your instrument cluster is for the emergency brake. Might check the connection on the rear
Old 06-20-2007, 03:35 PM   #3
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
it can also mean you are low on brake fluid, well it might be different for American cars.
steve-o is offline   Reply With Quote
Old 06-22-2007, 03:23 PM   #4
NibCrom
It turns out you're both right.
I was very low on brake fluid. I think I may have busted one of my brake lines when I ran over a couch cushion.
And the light does come on when I turn on the e-brake.
Now I just gotta find where the leak is.
Old 06-22-2007, 04:25 PM   #5
oh so you just run over couches for fun? i should try that sometime
Old 06-22-2007, 07:42 PM   #6
NibCrom
Yes, I ran over a couch cushion on purpose in order to damage my car.
Old 06-22-2007, 07:50 PM   #7
That's not a very nice thing to do.
[ion] C2 is online now   Reply With Quote
Old 06-24-2007, 01:22 PM   #8
Vinalero
Vinalero's Avatar
You already run on cushions everyday lol
But I'm thinking couch cushion would make an even more confortable ride than bags
Old 06-27-2007, 02:20 AM   #9
There may not be a leak. Sometimes the light can be an indication that your brake pads need to be changed. Over the life of the pads as they wear, more fluid is retained in the calipers because the pistons are extending and that causes the fluid level to drop.
Old 06-28-2007, 03:54 PM   #10
NibCrom
I agree with that 100%, the reason I thought there might be a leak was that the level had never gone down that far before. And I only changed my brake pads a couple of months ago. I guess if the fluid level stays where it is for a long time then there is no leak!
Old 06-28-2007, 04:01 PM   #11
i guess you could assume that
Old 07-11-2007, 09:43 PM   #12
NibCrom
I think I found a spot where there is a leak. (Right rear brake pictured)
Old 07-11-2007, 10:04 PM   #13
yessir you might wanna fix that. or fill with brake fluid every day, but i'd personally fix it. Wierd spot to leak though, unless that bolt is all rusted through.
Old 07-12-2007, 07:46 AM   #14
NibCrom
I'm not sure exactly which part is leaking yet. I did notice that the bleed valve doesn't have a cap on it.
I dried everything off and then pumped my brakes a whole bunch. Couldn't get any more fluid out that I could tell.
