Old 07-19-2007, 06:00 AM   #1
el_espiritu
el_espiritu's Avatar
el_espiritu is on a distinguished road
Xtra CD-Changer at OEM Radio?
I have the OEM Radio buildt in and I'm wondering if there's a way to add a CD-Changer to that Radio?
Other question: What Double-Din Radios with MP3 Option will fit without lot's of work into the original shaft?
(And which ones of these Double-Din radios do not look like a child's play tool with 100 switches & knobs and displays which are lighter than any TV)
1999 Alero 3.4 in Germany
The Civic-CRX Site
el_espiritu is offline   Reply With Quote
Old 07-19-2007, 07:31 AM   #2
any cd changer with the fm modluaor will work and i belive dbl dins wont work in the aleros with out modding the plastic piece with hvaoc also ive never seen a double din radio that didnt look retarded minus dbl din dvd nav units
Old 07-19-2007, 08:04 AM   #3
el_espiritu
Originally Posted by pimpalero2003 View Post
any cd changer with the fm modluaor will work and....
What's an fm modluaor? I'm sure you mean "modulator" but what's this?
A kind of adapter?
The Civic-CRX Site
Old 07-19-2007, 05:44 PM   #4
it will actually play the cds and stuff thru a radio station
Old 07-20-2007, 01:09 AM   #5
Depending on what plug additional plug you have in the back of the radio, you might be able to use a E&C bus changer.
Old 07-20-2007, 06:32 AM   #6
RoninKouga
double din
do double din nav units fit into the alero radio slot?
i'm thinking about installing a "kenwood 7200"
any thoughts?
Old 07-20-2007, 06:35 AM   #7
uhave 2 mod the schroud around it
Old 07-20-2007, 05:40 PM   #8
RoninKouga
... beein german i hope i may ask
what is a schroud ?? o_O
Old 07-21-2007, 01:02 AM   #9
I have a factory double din nav unit in my Alero (from a '05 Rendezvous). It was a tight squeeze in there, but i think the aftermarket double din units are smaller.
Old 07-22-2007, 09:45 AM   #10
el_espiritu
OK, solutions sounds not really worthy for me....
Problem with the FM Modulator will be that there's no control for the CD changer...
Nevertheless thanks to all for response.
The Civic-CRX Site
Old 08-27-2008, 01:12 PM   #11
zzyzzx
zzyzzx's Avatar
Unfortunately, there is no built in CD changer controller with the stock head units.
Quite frankly, I would almost have to figure at this point that it should be standard by now???
Old 08-27-2008, 03:34 PM   #12
The CD changer will come with a wired control that can be mounted some where easily accessed.
Old 08-28-2008, 02:08 AM   #13
It depends on which one you have...
Old 08-29-2008, 09:56 AM   #14
zzyzzx
zzyzzx's Avatar
OK then is it possible to plug and play with junkyard parts? If so does that depend upon the year?
Old 09-04-2008, 02:22 AM   #15
Yeah, it depends on the year and which radio you have to what changer you use.
Old 09-04-2008, 10:33 AM   #16
zzyzzx
zzyzzx's Avatar
If you could provide more details on this that would be helpful. For example if you know for a fact it only works on certain years stuff, etc.
Old 09-04-2008, 12:58 PM   #17
First start off with what year your car is... 99-00 use a "E&C" data bus while the 00-04 uses the Class 2 data bus to control the CD changer. I know for a fact that the '01-'04 base GX radio will not work with a changer. For the '01-'04 you need to have the additional 12 pin connector next to the 24 pin connector.
Old 09-04-2008, 01:33 PM   #18
zzyzzx
zzyzzx's Avatar
So are you saying that it's a no on the 1999-2000?
And for whatever reason, I'd have to think that the ones with the Cd changer would have more buttons or some sort of labeling to the effect, but I have yet to see a pic of such.
Old 09-04-2008, 01:38 PM   #19
No, just saying that the same one won't work in 99-00 as in 01-04. I believe the 99-00 should have a "aux" button.
