Old 08-04-2007, 11:07 AM   #1
blueialero
Fuel Pump not working??
hi all, yesterday my friend jacked up my car and replaced my fuel filter and now the car will only crank, no start. When i initially turn the car to "on", i don't hear the fuel pump whirring anymore....could it be like a relay or fuse or something or maybe the connection messed up when the fuel filter was replaced??
i tried searching to see how to figure out if your fuel pump isn't working and i think someone said to turn the car to on and then relieve the fuel pressure on the end of the fuel rail and if fuel comes out then its not the fuel pump right? please help, sarah
Old 08-04-2007, 11:59 AM   #2
blueialero
okay, i switched the fuel pump relay with the horn relay to see if it works and the fuel pump relay works fine and the fuel injector fuse looks good to me too, so its not that.
Old 08-04-2007, 01:08 PM   #3
Alero 2 Envy
Alero 2 Envy's Avatar
Alero 2 Envy is on a distinguished road
Check the wiring to make sure you didnt hit and un plug something. I have changed my filter twice with no issues.
1985 SVO Turbo with all the goodies !
Alero 2 Envy is offline   Reply With Quote
Old 08-04-2007, 03:24 PM   #4
comanche
comanche is an unknown quantity at this point
Is the security light blinking?
Also, it's easy to check if the fuel pump is unplugged.. your friend may have unplugged it for safety and forgot to plug it in again...
comanche is offline   Reply With Quote
Old 08-04-2007, 09:06 PM   #5
blueialero
no the ses light isn't blinking when the car is in the on position...i asked him about the plug and he said he didn't touch it, he said he removed the evap canister or something to get access to the fuel filter...i will see tomorrow if someone can look under there to see if anything is unplugged or i might even try to do it...thanx for all help
Old 08-06-2007, 10:44 PM   #6
blueialero
ok...i checked the plugs next to the evap canister this afternoon, unplugged the fuel pump connector and then reconnected it and it still won't work..
so im just wondering, when i have the tank dropped and take out the fuel pump assembly, how can i figure out if its a bad fuel pump or something else wrong with it?
Old 08-07-2007, 10:12 AM   #7
There's something with the fuel cut off. Push the pedal to the floor twice and on the 2nd time leave it there and the engine should turn over
Old 08-07-2007, 10:23 AM   #8
AGT
AGT's Avatar
Make sure he put the flow on correctly so that you actually get gas
Old 08-07-2007, 07:16 PM   #9
blueialero
make sure he put the flow on correctly? you mean the fuel filter? if so yes he did it right because the end of the fuel filter that screws in is screwed in and the other part that is held by the green connector is in there tight
and redog...you mean put the key to "start" keep it there and push the pedal to the floor once for a sec, let it up, then push it the floor again and hold it there? thanks ya'll
Old 10-04-2007, 11:46 AM   #10
I just wanted to say I love this guy!!!!
My Alero was very low on gas (running on fumes) I parked it and it sat for a week or two. Wouldnt start. Put 2 gallons in it, wouldnt start.
I was just searching E bay for a fuel pump, and I damned near spent $120.
Came across this post and figured, worth a quick shot.
She started up.
Thanks man! I thought I had to buy a fuel pump!
