Old 08-13-2007, 10:39 PM   #1
AsianAlero
AsianAlero is on a distinguished road
Send a message via AIM to AsianAlero
Which Magnaflow???
http://www.ajusa.com/cgi-bin/stores/details?vendor_code=MGN&ajr_part_number=MGN%201421 0&source=lookup&session_id=b3c671dcb7bc63416696026 98d49ae02
OR
http://www.ajusa.com/cgi-bin/stores/details?vendor_code=MGN&ajr_part_number=MGN%201226 6&source=lookup&session_id=b3c671dcb7bc63416696026 98d49ae02
Is there a disadvantage to have inlet and outlet on the same side like the first one? i noticed they only have one which is styled like that. and other brands dont even have that kind of design. seems like it wouldnt flow well.
AsianAlero is offline   Reply With Quote
Old 08-13-2007, 10:49 PM   #2
well your going to need to have dual tips for that muffler with 2 outlets
Old 08-13-2007, 10:49 PM   #3
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
there shouldnt be any problems with the inlet and outlet like that........if there is any restrictions of air flow, it will be very very minor!! as long as you have the rest of your cat back the same size as your inlet, you will be fine
Old 08-13-2007, 11:41 PM   #4
Spilner521
Boost Guru
Spilner521's Avatar
Honestly, neither of those will flow as well as a straight muffler. In both mufflers, the exhaust has to make a tight turn before it exits. Will you feel a difference in power over the straight muffler? No. With minimal mods like the exhaust you're planning and maybe an intake, it's not that big of a deal. When you start getting into cams, ported heads, and bigger power numbers, then you may feel a small difference.
As for those two, which one you pick depends if you want single or dual tips. Like Satsuriku said, just make sure the pipe diameter for the whole exhaust is the same size as the muffler inlet.
Old 08-14-2007, 12:34 AM   #5
99-alero
99-alero is on a distinguished road
while ur on the topic of exhaust..does any1 kno if the grand am gt exhaust set up will fit the alero?
99-alero is offline   Reply With Quote
Old 08-14-2007, 02:09 AM   #6
01silveralero
01silveralero's Avatar
yes it will fit.
Goal - Mid 11s all motor.
Old 08-14-2007, 05:29 PM   #7
99-alero
good 2 kno..im 2 cheap 2 go for after market right now lol
Old 08-15-2007, 01:13 AM   #8
But you also have to consider that in that Magnaflow muffler, the exhaust gas does have to make a 180° turn. However in many other performance mufflers they have to do much more than that. Turbo style mufflers are usually two 180° turns. Chambered mufflers essentially have a few walls that the exhaust gas goes into.
Oh, and it should be noted that Magnaflow uses the 14210 muffler in their exhaust kits for all off the Corvettes 1997 to current.
Old 08-15-2007, 02:33 PM   #9
Spilner521
Boost Guru
Spilner521's Avatar
That's true. Even with the sharp turn the Magnaflow will still outflow any chambered or other style mufflers out there. Like I mentioned, when using the muffler that pulls a 180° compared to the straight muffler, you won't feel any difference. I'm just one that likes everything to be as efficient as possible, which includes eliminating every little restriction in the exhaust. One little thing here and there won't make a huge deal, but all the little things add up
