Old 08-26-2007, 09:32 PM   #1
Aldog3788
Aldog3788 is on a distinguished road
tranny question
does any body feel that the stock tranny a 2000 alero shifts high outta first...mine prob shifts at like 3 grand...besides i already went through one
Aldog3788 is offline   Reply With Quote
Old 08-26-2007, 09:34 PM   #2
How hard is you accelration when it does this?
Old 08-26-2007, 09:58 PM   #3
Aldog3788
pedal 1/4 down mayby less
Old 08-26-2007, 10:18 PM   #4
Maybe it's slipping a bit, does it shift into 2nd hard?
Old 08-26-2007, 10:26 PM   #5
Aldog3788
a little...i jus got the effin tranny replaced
Old 08-26-2007, 11:02 PM   #6
TheEdgeofSanity
TheEdgeofSanity's Avatar
mine does that...usually shifts out of first at 3k at a normal acceleration. the transmission shop guy said it was fairly normal (had it in for a tranny fluid change).
2000 Chevrolet Malibu LS
Old 08-29-2007, 01:38 PM   #7
01AleroGL34SS
01AleroGL34SS's Avatar
01AleroGL34SS is on a distinguished road
I don't know if this will be of any help, but I'll give it a shot.
This is where my trouble begans, last week I discovered my battery was going bad. When I got to the repair shop to have my battery replaced, my transmission was fine, but after the battery was replaced, the transmission would slip between 1st and 2nd gear. If I shifted in manually, it was fine but if I let it shift itself it was slipping pretty bad, and even the shift between 2nd and 3rd was weak. I immediately called my dealer, explained to them what happened, and got the car over to them. After driving it, they told me the battery had nothing to do with my problem, and that my pressure solenoid was bad and I needed to get the valve bodies cleaned.
Not wanting to spend $700-$800 bucks, I called a local transmission shop. Turns out, when they replaced the battery, somehow the computer lost its memory. The computer didn't know when to shift the car! The mechanic plugged the car into his computer, and drove it around for like 25 minutes. He said to keep driving the car and the transmission would eventually go back to normal. Sure enough, that solved the problem.
I didn't know the Alero had a driver adapting transmission, but that was the problem. When they replaced your transmission, did they disconnect the battery? Any chance you could be experiencing the same kind of problem?
Almost forgot, my Alero has the 3.4 V-6
01AleroGL34SS is offline   Reply With Quote
