Old 11-28-2007, 05:41 PM   #1
DarkStar
DarkStar is an unknown quantity at this point
opinions on amp
http://www.woofersetc.com/index.cfm?...duct_ID=24 34
Would this be a good amp to push two 1500 watt kicker L7's?
I've heard very good stuff about memphis but tell me what you think.
DarkStar is offline   Reply With Quote
Old 11-28-2007, 05:43 PM   #2
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
i'd look for something that puts out more power.
FrankTheTank is offline   Reply With Quote
Old 11-28-2007, 06:12 PM   #3
if u really eant memphis id go the 1000d or even better the 2000d
Old 11-28-2007, 06:20 PM   #4
no, you should have more power. that amp will only push 300w peak to each sub, you should have one that pushes at least 1200w peak to each sub, preferably 1500w peak to each. it will work, but it won't be very loud.
I've got 1 1200W L7 getting its full power pontential. its loud, but its not contest winning stuff. i wish i would have went with the 2200W L7 instead.
Old 11-28-2007, 09:26 PM   #5
ROFL, I'm sure L7's would love 210 watts. NOT.
That amp is teeny, you're going to need something waaay bigger.
Old 11-28-2007, 11:20 PM   #6
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
Ok first, what's the voice coil configuration on each L7?
Second, what is the most amount of money you are wanting to spend?
If you're still running a stock charging system, you will not be able to run allot of power. You don't want to clip those subs, because the L7s don't have the best build quality.
Fi-Alero is offline   Reply With Quote
Old 11-28-2007, 11:30 PM   #7
^ 2 or 4 ohm DVC models are avalible.
Old 11-28-2007, 11:58 PM   #8
Fi-Alero
Fi-Alero's Avatar
Yeah, but whichever one he has makes a difference. :P
Old 11-29-2007, 12:04 AM   #9
Fi-Alero
Fi-Alero's Avatar
Actually, if you are running on a stock charging system, the Clarion DPX11500 is what I would run. Does 1500rms at 1 or 2 ohms and is CEA rated. Also is around the same price as that memphis. Then in the future, if you want more power, that clarion is strappable. Clarion has made a name for themselves recently.
http://cgi.ebay.com/CLARION-DPX11500...QQcmdZViewItem
Old 11-29-2007, 07:20 PM   #10
Steven01
Steven01's Avatar
Steven01 is on a distinguished road
Just get the rockford P5002 or a P6001 That would put enought power for same price. Or just go crazy and get something thats 1500 watts
Steven01 is offline   Reply With Quote
Old 11-29-2007, 08:20 PM   #11
Fi-Alero
Fi-Alero's Avatar
Steven, he does have 2 of those subs. That rockford 5002 will only give 125rms to each sub (if each sub is dvc2ohm) and is not 1 ohm stable. The 6001 will only give each sub 300rms at 2 ohms and also is not 1 ohm stable. Both of those is extremely low power. 1500rms (750 for each sub) is not crazy, it's budget power.
Old 11-29-2007, 08:45 PM   #12
http://www.caraudiocentral.net/forum...ead.php?t=8687
The 500.1 will toss out a tad over 700 WRMS.
The 1000.1 will do about 12-1300 WRMS
