Old 04-25-2004, 07:03 PM   #1
dadirtybulldog
after messing around with my headlights and removing my foglights, my blinkers suddenly won't work!... when i try to use the blinker they won't even click (the clicking noise inside when you use the blinker)... i did remove the blinker bulb assembly from the headlight assembly, could that have something to do with it... can someone tell me how to fix this??????
Old 04-25-2004, 11:15 PM   #2
niral622
niral622 is an unknown quantity at this point
hmm, thats odd...to start with, check fuses, probably blew a fuse...next, I would probably check the connection to the signal bulbs again by unplugging them from the harness and plugging them back in....next (if that doesnt work) check the bulbs, are they blown out?....if either of those solutiosn don't work, try the diagnostic way of finding the problem: start at the wires goign to the bulbs and check that power goes to them when the bliners are on it probably won't....next go to the turn signal relays and see if they are getting power....if not, maybe you have a loose connection...
2003 Black GL - Sedan and No sunroof
niral622 is offline   Reply With Quote
Old 04-26-2004, 12:25 AM   #3
bigd6983
im not positive but if he doesnt hear the clicking that means the relay aint even clicking over so my thoughts would be the fuse, i dont think the bulb being blown or even not fully in the socket has anything to do with the relay clicking over although i may be wrong, the relay may need a resistance present to activate everything. check your bulbs, then check the fuse, the check the relay, then check out the wiring....that would be the way 2 go
Old 04-26-2004, 01:36 AM   #4
trickalero
i had the same problem.....believe it or not it's in the hazard light button.replace it and you should be good to go. i'm not sure how to check and see if thats the problem cause i took it to the dealer.jope i helped!
Old 04-26-2004, 08:36 AM   #5
blueyezalero
If your car is a 2001...GM is doing a recall this year on the blinkers. I had mine fixed last year as soon as I found out they decided to do a recall. Call Olds and tell them that you can't wait and you need it fixed now (if your car is a 2001)
Old 04-26-2004, 10:03 AM   #6
bigd6983
Or that could be the problem lol got to love free work done :0)......hope you get it figured out
Old 04-26-2004, 10:05 AM   #7
bigd6983
and an offtopic notice, bulldog why does your car look jdm style with the steering wheel on the passenger side?? or is it just early and i still cant see straight??
Old 04-26-2004, 10:12 AM   #8
misslindseysue
Silent flipped the picture to make his sig.
Old 04-26-2004, 12:13 PM   #9
dadirtybulldog
thanks guys!... my problem just seemed to be a bad connection.... i unhooked everything and hooked everything back up... now it works!....my fault for bothering everybody...
Old 04-26-2004, 12:29 PM   #10
bigd6983
no bothering, just glad u got that problem fixed.....
Old 04-26-2004, 12:42 PM   #11
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
still if it does it again watch for the hazard switch, they did a recall on em
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 04-26-2004, 02:24 PM   #12
dadirtybulldog
they recalled the hazard switch for the 1999.. i thought it was the 2001????
