Old 02-02-2008, 11:00 AM   #1
Alon Alero
Alon Alero's Avatar
Alon Alero is on a distinguished road
Send a message via ICQ to Alon Alero Send a message via MSN to Alon Alero
Filter noise
I know, this might b a real stupid question but i just wanna know why cant u hear the noise that the filter makes (wai or cai doesnt matter) when the car isnt moving. i mean if u try to revv it at parking, u won't notice any sound difference but once u DRIVE and the rpm gets high u can hear it. what does it has to do with?
I hope this doesnt sound too stupid
Alon Alero is offline   Reply With Quote
Old 02-02-2008, 11:05 AM   #2
i hear it o_O
Old 02-02-2008, 11:34 AM   #3
alerored04
alerored04's Avatar
i think it has to do with there being a load on the motor.
My car breaks alot.
Old 02-02-2008, 12:04 PM   #4
ya like my s/c doesn't really whine unless i'm driving
i thought he meant "filter noise" as in, being able to hear air being sucked through a filter, lol
Old 02-02-2008, 12:28 PM   #5
Vinalero
Vinalero's Avatar
If you Rev it only, you wont hear the rumble of a cone. But if you punch him gas real fast when you are in park, you will hear it a bit.
Old 02-02-2008, 12:40 PM   #6
Alon Alero
Alon Alero's Avatar
Nah, its not even close to how it sounds like when youre driving. u can only hear the sound of the tb opening when revving.. and what do u mean "it has to do with there being a load on the motor"?
Old 02-02-2008, 01:13 PM   #7
alerored04
alerored04's Avatar
the motor has to work harder when the car is driving because there is weight to pull and an actual load on the trans and through that the crank. In park or neutral there is no load on the trans so the rpms can jump up quickly without having to pull a lot of air through the filter. It takes more air to make the power to pull 4,000 rpm while driving than it does while you are in neutral.
My car breaks alot.
Old 02-02-2008, 01:28 PM   #8
Alon Alero
Alon Alero's Avatar
Ah, yeah, how didnt i figure that out..
thx.
Old 02-04-2008, 08:34 PM   #9
I can hear mine
