02-28-2008, 10:48 AM
Shifter Position Indicator
Just wondering if the PRND321 indicator is suppose to light up at night with the rest of the interior illumination. Mine has not since I purchase the car and I didn't want to tear the console apart without knowing. If it does in fact light up, what is the bulb number? Sorry if this is a repost.
02-28-2008, 10:49 AM
i dont think so, mine doesnt either
02-28-2008, 11:04 AM
Something you can check that's easy to get to before you go tearing into the dash.
The module on top of the transmission where the linkage attaches has two plugs that come out the side (it's a flat black box that bolts down around the linkage shaft). The large one controls your backup lights, etc. The smaller one is the one that has 4 wires, and is your "Range" switch that tells the computer and dash panel what gear your selecting. That's where the signal originates. Just make sure it's plugged in solidly and look to see that the wires are intact before going further. When that plug is disconnected, the lights on your dash go out. Could be just the bulb(s) in your dash, but it's easier to get to the Module on top the tranny first.
02-28-2008, 11:33 AM
i think hes talking about the ones actually on the shifter where the pnd123 are in the center, not the ones on dash in the gauge cluster
02-28-2008, 11:37 AM
Mine does not light up either
02-28-2008, 11:42 AM
disregard
Reason: half asleep and being retarded
02-28-2008, 11:44 AM
the indicator by the shifter is supposed to light up, there is a little bulb in there but I can't remember the number sorry.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
02-28-2008, 11:58 AM
Trying To Help
194 Bulb
03 OLDS ALERO
02-28-2008, 12:00 PM
mine lights up.. i think
02-28-2008, 12:14 PM
Pull up on the shifter console part. Its not hard to remove. There will be a bulb and wire going to the center of the PRD321
Have a good day
02-28-2008, 05:23 PM
Yep ... there is a light there and mine lights up as it is suppose to do.
02-28-2008, 05:50 PM
The Founder
Yes, there is a 194 bulb in there, and it actually can fall out of the plastic clip it snaps into pretty easily. Just take off your gear shifter handle (its held on by a staple on the front of the shifter), and pull up on the bezel. The part will pull up.
02-29-2008, 03:03 PM
Ok, so I took the top of the console apart at lunch and found the bulb. It looks like some IDIOT took the console apart at one time or another and ripped the positive wire out of the harness. So, I replaced the bulb and reattached the wire. Now it lights up like it should!  Thanks for all your help!
03-01-2008, 01:49 AM
Another enlightened Aleromod customer.
03-01-2008, 12:31 PM
Although that is good to know as well, I rarely look at it when I change gears since the dash already offers you a selection right in front of you. Also, most of us change gears by simple memory nowadays, right?
