Old 05-20-2008, 05:38 PM   #1
rleach01
rleach01's Avatar
rleach01 is on a distinguished road
squal
ok well i have a high pitched squal coming from the pulley area, its not the belt so i thought it was the ideler pulley i i changed it any ideas cant the water pump make that noise and the sound coming from the front of the pulley system
rleach01 is offline   Reply With Quote
Old 05-22-2008, 07:53 PM   #2
rleach01
rleach01's Avatar
bump..... come guys i need your help
Old 05-22-2008, 08:07 PM   #3
a/c compressor maybe, lube it up
Old 05-22-2008, 08:12 PM   #4
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Turn your AC on and see if it stops. The clutches I believe can make some pretty good noise when they are going bad. My Cutlass used to squeal like a beast, and when I turned the AC on it was solved because it ingauges the clutches.
Old 05-22-2008, 08:56 PM   #5
-Alero-
-Alero-'s Avatar
whats a squal? isnt that some sort of fight/dispute?
AUTOBOT
Old 05-23-2008, 11:22 AM   #6
olds03alero
olds03alero's Avatar
olds03alero is on a distinguished road
Send a message via AIM to olds03alero
check your crank pulley, with the car running see if it looks like its wobbling. i just had to replace mine last week for the same problem.
olds03alero is offline   Reply With Quote
Old 05-23-2008, 02:49 PM   #7
blueolds01
blueolds01's Avatar
blueolds01 is on a distinguished road
Send a message via AIM to blueolds01
we had a squeky alternator at the shop one time...
HAS
-'01 alero "442"
3.4 v6, 8.2 taylor wires, 2 10's , WAI, 2.5" custom cat-back exhaust w/ dual super 40 mufflers and, KYB-GR2 struts. 15.701@87.69mph.
-'97 s10 4.3 v6, alpine head unit, camaro rims, 2.5" cat-back w/Edelbrock SDT, Edelbrock TES headers, HPPIII, and 8mm taylor wires. 15.505@87.42mph
http://www.cardomain.com/id/s104-banger
videos-
http://youtube.com/watch?v=YvkbtiBirVo
http://youtube.com/watch?v=WnmqBZkdmAM
blueolds01 is offline   Reply With Quote
Old 05-23-2008, 06:45 PM   #8
You mean squall?
