Old 05-23-2008, 05:07 AM   #1
Marrko
Marrko's Avatar
Marrko is on a distinguished road
Send a message via Yahoo to Marrko Send a message via Skype™ to Marrko
Dead engine!!!
As the title says my engine is dead... A mechanic at a shop sayd the main crankshaft (i believe that's how it's called) is effed up. (he said i need to take the whole engine out, part it out try fixing whats effed up and then put everything back in one piece). |||| I have a horible ticking sound in the engine, and as the rpm goes up the noise becomes louder and the engine stubles harder and harder... Because i'm in lithuania rebuilding the old engine cost's horrible money, so now i'm looking for an engine, with lower miles as posible. While browsing the internet i came accross with this:
http://engine-doctor.com/shop/produc...products_id=73
So now i want to ask you all qestion. is it a good choise or i should search for something else? it's the quad engine so what mods i'll have to do to maike it work insted of my stock 2.4l ?
another option i found was to order a new engine from GM (i don't care if it costs me 2800$ for the engine and about 600$ for shipping IM NOT SELLING MY BABY!!). What do you guys think?
Please help me ppl i'm in desperate need of help... I don't know what to do.. maybe someone knows where to look for a angine? please give me links... any help is apretiated... I count on you guys!!! I'm waiting for your posts....
The Black Devil ---> American Heart and Soul representer in Europe....
Marrko is offline   Reply With Quote
Old 05-23-2008, 05:14 AM   #2
Marrko
Marrko's Avatar
sorry for the triple post!!!! f$%$#%$ internet conection... please delete and leave one thread!!!
Old 05-23-2008, 06:18 AM   #3
more details, crankshaft doesn't tend to break on the LD9. did he say "main bearings, the ones around the crankshaft"?
Old 05-23-2008, 07:48 AM   #4
ion, didn't you just order a cheap engine??
Old 05-23-2008, 07:54 AM   #5
I picked up a used engine with 30k miles for $125, yes. But I'm not sure if he can find a deal like that in Lithuania. I got mine off a local person.
Old 05-23-2008, 08:31 AM   #6
Marrko
Marrko's Avatar
ion i don't know how to say that word in english i know that it has to do with shaft and the things around it, but i'm talking not about the litle camshafts but about the main one in the lower part of the engine...
Old 05-23-2008, 08:39 AM   #7
Right, it's the crankshaft. It might be that just your main bearings are spun:
So you'd need a new crankshaft or resurface it and get the correct size bearings. If that's what it is it shouldn't be too bad to replace.
Old 05-23-2008, 08:41 AM   #8
CBLOHM3400
Trying To Help
CBLOHM3400's Avatar
CBLOHM3400 is on a distinguished road
Send a message via Yahoo to CBLOHM3400
if he spun the beaqring in the journals block and bearing caps would have to be machined
03 OLDS ALERO
CBLOHM3400 is offline   Reply With Quote
Old 05-23-2008, 08:44 AM   #9
Yeah nevermind on the easy. The main bearings going causes a lot to fix.
It might just be a spun rod bearing, which goes on this engine quite a LOT. The #3 cylinder's rod bearing.
Old 05-23-2008, 08:49 AM   #10
Marrko
Marrko's Avatar
would this be what i need?
http://cgi.ebay.com/ebaymotors/GM-QU...spagenameZWDVW
Old 05-23-2008, 09:17 AM   #11
Talk to more mechanics. Is your mechanic SURE of what the problem is? Don't buy a bunch of parts without knowing for sure what's destroyed.
Old 05-23-2008, 09:30 AM   #12
Marrko
Marrko's Avatar
whel i went to 3 mecaniks that are know to be the best ones in my city and all of them said the same thing... i gues i have to risk, to buy a new engine or take the car to the shop and let them part out the engine and look whats destroyed and ect.... crap one way or another all of this will cost me 2000 - 4000$
Old 05-23-2008, 10:54 AM   #13
Well that sucks but if I were you I would get a new one (or remanfactored) one directly from GM. I would only do this if the warranty will be vaild in the EU. That you will have to look into, not too sure if the warranty is vaild outside North America.
This is probably you're best option. Your motor is not a rare one and can be easily replaced. If the motor was an older one (like for the 1960's per say) a rebuild is you're best bet.
Also keep in mind a core charge. They will charge you an extra amount of money and refund it after you send them back you're old motor
I'm planning on doing something similar when my engine goes
Old 05-23-2008, 01:35 PM   #14
found this site that ships world wide worth checking out
rebuilt.com/Oldsmobile_engines
engine core shipping (WW)
OLDS 2.4 146 4 T 97 Quad 4 DOHC $1,790 $500 $200-$600
and it says they ship to lit. too
Old 05-23-2008, 07:19 PM   #15
Vinalero
Vinalero's Avatar
¨¨ I dont know if its the good engine over there. Theres no EGR since 2000 and Marrko has a 2001 I think.
at a point where you need to rebuild an engine, generally its better to just buy a new one and swap it in for a few more dollars.
You are going to pay a lot in labor just to rebuild the engine + the cost of broken pieces.
Old 05-25-2008, 12:34 PM   #16
Marrko
Marrko's Avatar
i know i want to buy a new engine and ect. BUT guys remember i'm from LITHUANIA, so this makes everything SO SO SO more complicated and the price off shipping is enormous (engine = alot of kg = allot of money). Basicaly for now i have found a mecanic that is going to try to rebuild my engine, he will take it all apart and see what damage is done at this time. I will keep you all updated... I need to repair my babay in 4 week, because just in 4 weeks i'm completing my secret project: I have ordered the AAS kit!!!!!!!!!!!!!!!!!!!! Soon i'll be the owner of the most modded alero in EUrope!!! i hope
thnx for your help guys!!!
Old 05-25-2008, 12:50 PM   #17
wahoo awesome
Old 05-26-2008, 03:28 PM   #18
CharleyO99Alero
CharleyO99Alero's Avatar
CharleyO99Alero is on a distinguished road
If it is found that you need a crankshaft kit, the one you posted above should be a decent one. I've used a couple of Standard crankshaft kits in the past for stock rebuilds without problems.
CharleyO99Alero is offline   Reply With Quote
