Old 05-25-2008, 11:19 PM   #1
dbailey
dbailey is an unknown quantity at this point
Turns Over, Fire at the Plugs but Won't Start????
My baby is starting to become a nightmare of a black hole all of a sudden. Everything's fine and without any warning, it won't start. Turns over fine, checked for spark at the spark plug and plenty of that. Any ideas as to what to check first from a fuel standpoint? Anybody ever had this happen to them before? Hope its not the fuel pump. Don't guess a throttle body engine will vapor lock will they? It was parked all day on a slight incline with the nose pointed up and was pretty hot today if that makes any difference. I have in the past noticed it having a slight problem starting when it has been pointed uphill. Hmmmm.....any suggestions? Thanks guys.
dbailey is offline   Reply With Quote
Old 05-25-2008, 11:27 PM   #2
dbailey
P.S. I can hear the fuel pump running when I turn on the key until it pressurizes or whatever it does.
Old 05-25-2008, 11:57 PM   #3
00oldsalero
00oldsalero's Avatar
00oldsalero is an unknown quantity at this point
Send a message via AIM to 00oldsalero Send a message via Yahoo to 00oldsalero
check fuses and relays and or possibly timeing chain not sure what the aleros have in the car will crank but not start
00oldsalero is offline   Reply With Quote
Old 05-26-2008, 12:04 AM   #4
Vinalero
Vinalero's Avatar
I guess if it was timing chain, he would have heard it the last time it was running.
But liek he said, Id start from the basic like you did and go up like with fuses, etc.
I'm thinking, you were on an incline with the nose up, is your fuel tank almost empty? (I know its dumb, but I've seen it too often)
Old 05-26-2008, 01:26 AM   #5
AftermathAlero
I've had a sounding fuel pump and not work. To really check the fuel pump is to unscrew the cap at the shredder valve. stick a philips screwdriver in the needle thingy (forgot the term, LOL). put a towel over the area tho as gas will spray out. then put the car in run real quick. If there fuel coming out then its not the fuel pump. If there is nothing, then its ur fuel pump. Or low on gas.
check that tho.
Old 05-26-2008, 10:25 AM   #6
misslindseysue
MINIac
misslindseysue's Avatar
misslindseysue is an unknown quantity at this point
Send a message via AIM to misslindseysue
All I know about making a car run is it's a three term equation. You need fuel, air, and spark. If you know you have spark, follow the other two back to their source and make sure you have them in the correct amount and at the right time. Fuel could be a low tank, bad pump, clogged line, bad injector, etc. Air could be a bad sensor or something worse, but that's usually the one you don't have to worry about.
misslindseysue is offline   Reply With Quote
Old 05-26-2008, 10:52 PM   #7
blueolds01
blueolds01's Avatar
blueolds01 is on a distinguished road
Send a message via AIM to blueolds01
has your security light come on at all?
HAS
-'01 alero "442"
3.4 v6, 8.2 taylor wires, 2 10's , WAI, 2.5" custom cat-back exhaust w/ dual super 40 mufflers and, KYB-GR2 struts. 15.701@87.69mph.
-'97 s10 4.3 v6, alpine head unit, camaro rims, 2.5" cat-back w/Edelbrock SDT, Edelbrock TES headers, HPPIII, and 8mm taylor wires. 15.505@87.42mph
http://www.cardomain.com/id/s104-banger
videos-
http://youtube.com/watch?v=YvkbtiBirVo
http://youtube.com/watch?v=WnmqBZkdmAM
blueolds01 is offline   Reply With Quote
Old 05-27-2008, 11:39 AM   #8
dbailey
Thanks all. As stupid as it sounds, I had just less that a quarter of a tank of gas and the pick up must be in the front of the tank. After I rolled it onto flatter ground and cranked on it awhile, it started up. Thanks for the ideas though for future reference!
