Old 05-26-2008, 05:13 PM   #1
Raziel
Raziel's Avatar
Raziel is on a distinguished road
JVC KD-NX5000 HU, with Navigation
Hey all, was just wondering about the following HU, It has a built in navigation system, but it needs the VSS Wire hooked up so that it can calibrate the Navigation, Does anyone know where the VSS(vehicle Speed Sensor)wire is on the stock Stereo harness or where I could run this particular wire, Thanks In advance. I have read the other posts about this issue, and I am having a hard time finding the wires for pin 64 and 65, is connector 1 the left or the right side.
Raziel
Raziel is offline   Reply With Quote
Old 05-27-2008, 02:12 AM   #2
What year/engine is your car?
Old 05-27-2008, 11:11 AM   #3
Raziel
Raziel's Avatar
Mine is the 03 Alero GL, 3400 V6.
Old 05-27-2008, 01:49 PM   #4
The wire color is Dark Green/White and goes to your PCM, Connector 1 (blue) Pin 55. You can also pick it up at connector C200 which is a little 18 pin connector near the PCM by the steering column (has a little flip lock on it). It's pin B3, also Dark Green/White.
Old 05-27-2008, 02:00 PM   #5
Raziel
Raziel's Avatar
Thanks I will try that and get back to ya on how it goes, would you be able to post pics of those particular connectors that you are talkin about just incase and maybe point out the wires.
Raziel
Old 05-27-2008, 05:29 PM   #6
Raziel
Raziel's Avatar
Scratch that about the pics, dude you are great, it works and thanks for all the help on this subject. Been lookin for info for the last week and a half since I bought the thing.
Raziel
