Old 05-28-2008, 12:16 AM   #1
kniedelm9490
kniedelm9490's Avatar
kniedelm9490 is on a distinguished road
Send a message via AIM to kniedelm9490
amp problems (lol for ryan )
my friend gave me his kenwood amp from his old car when he got hit and im not sure if its broken or not or something came loose.
i plugged in the amp it powers up but when we plug the rca in and the connect the subs nothing comes out is the amp broken? or is there something i can do to fix it?
kniedelm9490 is offline   Reply With Quote
Old 05-28-2008, 07:47 AM   #2
Well if its hooked up correctly, the fuse isnt blown and no sound...
Either something not right with the input source (RCAs, head Unit has RCAs out turned off?) then its the amp.
Not worth fixing.
Old 05-28-2008, 07:47 AM   #3
check the fuses. if those aren't blown, you can open it up and check the soldered joints on the circuit board. the accident might have just jarred one loose which would cause it to not work. might just be as easy as putting a couple small beads of solder back on the circuit board.
