06-01-2008, 01:00 PM
Wow, that sounds... well bad. My parents looked at a malibu that made that sound. Hopefully it isnt too bad. Good luck
06-01-2008, 01:16 PM
sounds like a rod knocking.
06-01-2008, 01:52 PM
so if its a rod about how much you think im gonna be looking at to fix it?
06-01-2008, 04:32 PM
a couple grand.
06-01-2008, 04:57 PM
so my friends dad just came and looked at it and he thinks its either the rod or a valve, yah! anyways, i aint paying another 2 gs to fix it again, so me and him are gonna take it to his house and take it apart later this week and look at it, sad thing is i paid 2 gs in october to fix the same thing except then my engine had locked up to where it wouldnt start. right now it still starts
06-01-2008, 06:04 PM
take it back to the person who originally worked on it, or just spend 1,300$ on an extended warrenty? and then pay 100$ and have the stealership do it right?
otherwise pay an arm and a weiner
AUTOBOT
06-01-2008, 06:26 PM
^^ what he said :<)
06-01-2008, 06:48 PM
Wtf Rod Knock Yo!
06-01-2008, 07:22 PM
Wide Open Throttle
Just get another motor and throw it in there. Cheaper. If it did this before and was fixed, it sounds like the real problem wasn't fixed (sorry, obvious). Partially plugged oil galleys, out of round journals, bad oil pump, etc.
car-part.com or ebay. under 1000 easily if you can do the labor yourself.
06-01-2008, 10:37 PM
Yeah it's def a rod. you didn't help it too much by revving it, but the motor is shit now anyway.
No dealership is going to give you anything for that car, swap the motor. save yourself a ton of cash
06-01-2008, 10:41 PM
x2
replace fo sho
HAS
-'01 alero "442" 3.4 v6, 8.2 taylor wires, 2 10's , WAI, 2.5" custom cat-back exhaust w/ dual super 40 mufflers and, KYB-GR2 struts. 15.701@87.69mph.
-'97 s10 4.3 v6, alpine head unit, camaro rims, 2.5" cat-back w/Edelbrock SDT, Edelbrock TES headers, HPPIII, and 8mm taylor wires. 15.505@87.42mph
http://www.cardomain.com/id/s104-banger
videos-
http://youtube.com/watch?v=YvkbtiBirVo
http://youtube.com/watch?v=WnmqBZkdmAM
06-03-2008, 09:30 PM
Uh,
Dunno, my cousins Grand Am had that and his dad fixed it. 2 years ago.
06-03-2008, 09:36 PM
Step 1: pull the valve covers and look for loose rocker arms and/or a broken valve spring.
06-03-2008, 09:39 PM
i really feel bad for u dude.....dont drive unless absolutly HAVE TOOOOO!!!!
Did u overheat it?
06-03-2008, 11:37 PM
nope the temp was fine, i had went to store and was on the way back and it started making that noise, yah hopefully tomorrow we are pulling the valve covers off to look there first
06-03-2008, 11:49 PM
Gotta love the quad 4, I have owned two and both of them had engine problems with under 100K on the clock.
The worst was a 97 cavalier that threw a rod through the block, which in turn started a fire under the hood. The other is in a 99 grand am that is sitting in my garage with metal flakes in the oil.
06-04-2008, 12:13 AM
If this is in the right category, this is a 3.4 liter lol
06-04-2008, 06:35 PM
lol ya i didnt wanna say anything i was just gonna let him be
06-04-2008, 07:23 PM
You spun a bearing dude. Sounds like it may also have bent the crank, or the bearing is really trashed, with that loud of a knock... Drain the oil, look for copper flakes. Remove the oil filter, cut it open, and if it contains the following, then it is a spun bearing:
