Old 06-26-2008, 09:06 PM   #1
Brakes sticking
well when i get im my alero first time for the day, ill take off(after waiting ten minutes for that friggin passlock)my brakes will stick a bit(not so much that it will really stop the car, just hold it into place)and as im driving fighting the stuckness it will just ease out a but after pumping......i dont get it????? maybe time for the corvette brake upgrade?
BTW- New alero = 2000 Red coupe 2.4L motor 65879 miles (last time i had an oil chance which was tuesday)
Old 06-26-2008, 09:12 PM   #2
Sounds like a frozen caliper. It happens.
Is it leaking brake fluid at all? That happens sometimes becuase the fluid has nowhere to go in this case
It's up to you about the Corvette brake upgrade. It's a bit more expensive than replacing the stock caliper, and you need 17 inch wheels to do it.
If you have that, by all means DO IT!! It would look awesome.
A guy on GAGT did fit 16 inch Grand Prix wheels on there. The 5 start ones with the really thin spokes. I think the offset on them is +56mm
Old 06-26-2008, 09:16 PM   #3
seized caliper piston, time for new calipers
check for leaks around caliper area, check brake fluid level. take it to a brake shop and have them check out which one(s) is/are leaking and put on some new calipers
Old 06-26-2008, 09:24 PM   #4
no brake fluid leaking...actually no leaks at all(lol)
is it dangerous to keep driving?
i have like virtually no money right now and i really need to go to work
(54 mile round trip)
Old 06-26-2008, 09:48 PM   #5
probably not, but it will wear your pads down. and if your pads seize and won't move when you need brakes, you're effed
Old 06-26-2008, 10:00 PM   #6
would the emergincies work?(plus i really dont use my brakes when im goin down the highway at 85 MPH, lol i know i am being stupid but......)
Old 06-26-2008, 10:01 PM   #7
TheEdgeofSanity
TheEdgeofSanity's Avatar
could the brakes need bleeding? i mean, maybe there's air in the lines somewhere for whatever reason? or what about a master cylinder?
2000 Chevrolet Malibu LS
Old 06-26-2008, 10:04 PM   #8
hmm symptoms of a master cylinder(other that brakes sticking)BTW Cherrington your quote was too funny, i dont know why but i laughed my ass off....lol too much wacky tebacky!
Old 06-26-2008, 10:05 PM   #9
those could be the problem or part of the problem as well, that's why i say go get it checked out! brakes are not to be taken lightly.
yes the e-brake always works, as long as you have rear rotors and wheels/tires. and the cable isn't broken.
btw cherri didn't post in this thread
Old 06-26-2008, 10:06 PM   #10
oops.... Goddamn i always screw up when im between three threads!
anyway ill go tommrow after work(pray i dont die tommrow!)
Old 06-27-2008, 01:34 AM   #11
AJules
AJules's Avatar
AJules is on a distinguished road
this happened to me just last week
if you don't fix it soon, you're gonna wear down your brake pad in no time driving 54 miles a day
you can ignore the problem, but it's probably just going to get worse
then you're probably going to end up needing a new caliper (160 bucks)
I'd just take it to some place and have it checked out, a lot of places do it for free, I just got mine checked out at Michel tire for free and even though they couldn't fix it, they still explained what was wrong.
AJules is offline   Reply With Quote
Old 06-27-2008, 06:31 AM   #12
new caliper is $60, $30 labor generally.
Old 06-27-2008, 12:42 PM   #13
AJules
AJules's Avatar
lol, Michel tire must be a complete ripoff
they told me it was 160 bucks per caliper for new ones
don't go there then
but anyway wouldn't he need to get two calipers anyway though?
If you replace one with a new one but still have an old one won't you feel a pulling to the side of the new caliper when you brake?
Old 06-27-2008, 01:14 PM   #14
I just went through my pins beinging seized. One on each side and all it did was cause my pads to wear down really fast and uneven. If it is indeed the pins seizing they make a kit to replace the caliper clips and the pins and pin boots. That would be the way I would go as long as the brake piston is good. It's a bitch to get them out but if you know some one with a torch, have them heat them up and it will pop right out. Once its out its a piece of cake, but DO NOT and I will repeat this because it is do important...DO NOT ring the head of the pin off because you will have screwed yourself in the behind with no lube. Don't forget the high heat grease when putting the new pins in, and wha la fixed. I don't have to tell you about having to get the new pads.
Old 06-27-2008, 01:42 PM   #15
don't go there then
ya they'd be anally raping you there
no, i got only one caliper replaced when mine leaks, brakes evenly. if the caliper's not bad it's not going to affect anything
Old 06-27-2008, 02:03 PM   #16
Trickyslick
Trickyslick's Avatar
Yeah I got quoted $160 also for a sticking caliper...parts and labor
Old 06-27-2008, 02:07 PM   #17
$90 installed for me at a local place, Muscat Tire, not a chain
Old 06-27-2008, 11:22 PM   #18
well got new slotted rotors, new calipers, pads, all for 521 dollars installed at my local place....all good now MAN CAN I STOP QUICK!
Old 06-28-2008, 03:51 PM   #19
super white alero1
Trying to get it together
super white alero1's Avatar
Get it fixed. If you don't have cash then the corvette upgrade is not for you. Save up. GL
Old 06-30-2008, 10:33 AM   #20
got it fixed TWO posts above!
