Old 07-21-2008, 12:33 AM   #1
AleroGLS
AleroGLS is an unknown quantity at this point
Wheel Hub... Which one.....
Hello all,
I know the bearing is gone in my car but im just not sure which one is shot. One moment it sounds like it is coming from the passenger then from the driver side the next. Any help would be great. Thanks
<img src=\'http://img55.photobucket.com/albums/v167/chochie21/banner.gif\' border=\'0\' alt=\'user posted image\' />
AleroGLS is offline   Reply With Quote
Old 07-21-2008, 12:40 AM   #2
JOEY GLADSTONE
JOEY GLADSTONE is on a distinguished road
you should be able to feel the difference in the vibration throughout the car, if not i think there was a trick with jacking up the car and checking the play in the wheel
JOEY GLADSTONE is offline   Reply With Quote
Old 07-21-2008, 01:03 AM   #3
When you turn, does the sound change?
Old 07-21-2008, 07:02 AM   #4
If you turn and the sound goes away whichever way your turning- thats the bad one.
Get a long piece of small wood. Have someone else drive and place the wood to the farthest corner front- closest to wheel. Putt wood on your ear so you can hear the vibration. Check both sides.
Old 07-21-2008, 08:50 AM   #5
sound_xtreme
sound_xtreme's Avatar
buy the new hub and plug it in each wheel till the dash lights go off.
Cardomain
Old 07-21-2008, 11:19 PM   #6
AleroGLS
Yes it does change, One way it gets softer and one way it gets louder, Cant remember which way is which at the moment.
Old 07-28-2008, 01:23 PM   #7
zzyzzx
zzyzzx's Avatar
Is'nt this the type of thing that should be replaced in pairs?
Old 07-28-2008, 01:57 PM   #8
zoomie
zoomie's Avatar
zoomie is on a distinguished road
I've replaced both of mine at different times, both because of speed sensors not noise. You can test the speed sensors with an ohm meter, but if they're just noisy and not setting of the dash lights you have to go with a hard corner to the left, if it gets louder then it's the right bearing, then a hard corner to the right, if that's louder then it's the left bearing.....
2003 2.2 5sp.
Tight Lines..............................
zoomie is offline   Reply With Quote
