Old 08-05-2008, 09:46 PM   #1
CactusWill
Replaced Blower Motor Resistor... Still Doesn't Work ?
Replaced the blower motor resistor with a brand new AC Delco one, and the blower still only works on the highest speed. What else could it be?
Old 08-05-2008, 09:55 PM   #2
TheEdgeofSanity
TheEdgeofSanity's Avatar
just check the fuse. i know it sounds stupid, but i had mine only working on high and i checked the fuse for kicks and giggles and it looked burned out. i changed it and everything was fine.
2000 Chevrolet Malibu LS
Old 08-05-2008, 10:23 PM   #3
CactusWill
I checked all the fuses when I first got the car, I'll check them again but I don't think thats it...
Old 08-05-2008, 10:34 PM   #4
shez
shez's Avatar
shez is on a distinguished road
Send a message via AIM to shez
I've had a problem with my AC too. It started to only work on the 2nd and 3rd highest settings. Nothing else. Then it gave out and four days later it started working again. It just stopped working again like last week and I don't think it's going to make a comeback again.
You think the changing the fuse could fix it? Also, how much is a new blower motor?
shez is offline   Reply With Quote
Old 08-05-2008, 11:20 PM   #5
Midgear
on vacation
^^^ I dont think its the motor itself- I think its the Blower Motor Resistor- its like a 20 - 30 dollar part.
WILL NEVER FORGET
Old 08-05-2008, 11:35 PM   #6
check fuses again if the resistor is new. there is more than one fuse for the blower motor.
Old 08-11-2008, 05:48 AM   #7
CactusWill
lol... Thank you sir, but the title of this thread is ' Replaced Blower Motor Resistor... Still Doesn't Work '
Checked all the fuses, twice over. Any relays that could be bad? Anything? Help guys.
Old 08-11-2008, 05:54 AM   #8
Vinman
Vinman's Avatar
Vinman is on a distinguished road
Send a message via AIM to Vinman Send a message via Yahoo to Vinman
you also could have a defective resistor ( not saying you do, but its possible)...which sucks 'cause I'm pretty sure you can't return it once its installed..
Vinman is offline   Reply With Quote
Old 08-11-2008, 05:56 AM   #9
CactusWill
The one that I replaced wasn't even bad... Its something else
Old 08-11-2008, 06:49 AM   #10
Vinman
Vinman's Avatar
the 3 that i've replaced didn't look bad either, and work everytime with the new resistor..maybe you do have a seperate problem..maybe it could be the switch itself?
Old 08-11-2008, 06:59 AM   #11
CactusWill
It could be the switch itself, but I highly doubted it at first.
Old 08-11-2008, 07:04 AM   #12
Alero_1986
Alero_1986's Avatar
Alero_1986 is on a distinguished road
I replaced the blower motor resistor on my girlfriends sunfire a few years ago with a new AC delco part. The new resistor was DOI. I returned it for a new part and it worked just fine. If you are still able to use certain speeds I would still suspect the resistor. You could always return it for another part if it is easily accessed.
Alero_1986 is offline   Reply With Quote
Old 08-11-2008, 07:55 AM   #13
anyone really know how the resistor works? (i've never really seen one) I guess theres suppose to be some kind of differing resistance on each contact. Does the resistor only go in one way, or is it possible to install backwards?
maybe find the old one and throw an ohm meter across each contact, then try the new one, see if there is a difference.
...and if someone could test a new one, that is definitely functional, and let us know what specs we're looking at....
at least that way we'll definitively know if its dead, or your searching somewhere else.
maybe check the contacts on the switch, with the car on, to see if you have power going to the switch? Your motor certainly works, its just a matter of figuring out where after that, it died.
Old 08-11-2008, 03:29 PM   #14
CactusWill
Yes it only goes in one way, its not possible to install backwards without modification.
Old 08-11-2008, 04:35 PM   #15
if the original wasn't bad, and you replaced it with another one that wasn't bad... how do you know both weren't bad?
Old 08-11-2008, 05:19 PM   #16
CactusWill
I don't know for sure whether the old one was bad or not... But I had a mechanic friend there who was helping me out, when the old one came out, he said that it looks like it had already been replaced a couple times and might not even be the problem. Sure enough, we popped the new AC Delco one in, and nothing.
Old 08-11-2008, 06:26 PM   #17
Sometimes a fuse will look good but it is not.
Take a DMM to each fuse that deals with the blower motor. Check inside the car both spots and UNDER the hood.
If you dont have a DMM just replace all the ones for the blower motor.
Old 08-11-2008, 08:02 PM   #18
CactusWill
I do have one, but my mechanic did go over all of them with a test light. I think I'll just go ahead and replace all of the fuses anyways since I can get them for free, but I doubt its going to make any difference.
