Old 08-13-2008, 09:35 PM   #1
Alerosaint
Gone but not forgotten
Alerosaint's Avatar
Alerosaint is on a distinguished road
Send a message via AIM to Alerosaint Send a message via Yahoo to Alerosaint
alignment or wait
I just finished lowering my car...should I take it to get aligned asap or should I wait till its settled????
Alerosaint is offline   Reply With Quote
Old 08-13-2008, 09:41 PM   #2
Midgear
on vacation
I stuck eibach springs on my car and never got an alignment.. wheel stays straight and doesnt pull anywhere.. so I guess it's good-
WILL NEVER FORGET
Old 08-13-2008, 09:45 PM   #3
Alerosaint
Alerosaint's Avatar
no excessive tread wear or nuthin huh
Old 08-13-2008, 09:50 PM   #4
Midgear
on vacation
^^^ I can only chuckle at that one.. I've boiled rubber since I put those springs on- only to prove my point that my "granny cars" traction control doesnt work.
shoulda seen the look on their faces when that sheet of thick solid white smoke came seeping from the body lines on the hood-
WILL NEVER FORGET
Old 08-13-2008, 09:55 PM   #5
alignment = totally necessary according to most people, i dunno. i don't want to have to take my side skirts off again for a shop to use their damn chassis lifts.
you put them on yourself? i have a set of Sprint springs sitting here
Old 08-13-2008, 09:56 PM   #6
Midgear
on vacation
^^^ dude.. put them on your car for the love of all that is holy.. and then go get an alignment lol
once I figured out how to get the spring off the strut.. it was pie, first one took me about 2 hours LOL.. the rest took me around 15 minutes each
WILL NEVER FORGET
Old 08-13-2008, 10:28 PM   #7
I dunno..I had one done and I didn't have to take anything off to have it done. I had to call around to find a place that would do an alignment on a lowered car...that wasn't easy to begin with. The place that did it actually had 3 pieces of 2X6 nailed together like steps that they drove my car up to get it on the lift.
Old 08-13-2008, 10:41 PM   #8
Alerosaint
Alerosaint's Avatar
sure did...wasnt that bad really ...i actually pulled up the how to on the forum on my cellphone and used it as a guide...heh heh
once I figured out how to get the spring off the strut.. it was cake, first one took me about 2 hours LOL.. the rest took me around 15 minutes each
the first one did take me 2 hours, cause i had to learn how to take off the spring and made sure the springs were lined up right but after that it was not cake but pie....lol...just putting the bolt into the knuckle, getting it lined up was a pain in the arse...the last one kicked my butt to...i was spent
Old 08-13-2008, 10:45 PM   #9
Midgear
on vacation
omg.. thank you for pointing out the cake thing. *edits above post*
WILL NEVER FORGET
Old 08-13-2008, 11:03 PM   #10
JOEY GLADSTONE
JOEY GLADSTONE is on a distinguished road
you dont need to take off your skirts for the lift, in most cases you need to take off the front bumper unless you use wood blocks to get it up
JOEY GLADSTONE is offline   Reply With Quote
Old 08-14-2008, 01:43 AM   #11
Alignment racks have the ramps they drive on. No need to remove the rocker moldings.
Old 08-14-2008, 03:20 PM   #12
hmm maybe i was just thinking about the install, if i had a shop install em they'd likely use those same crappy lifts as Midas at ASS so they can take off the wheels and mess with the springs easily
i don't know how to install springs, lul. and i know it's not going to go smoothly, nothing rusted ever does. i thought you had to be like super careful and have a friend or two because the spring needs to be super compressed and whatever. and the old one could fly off or something.
Old 08-14-2008, 03:22 PM   #13
Midgear
on vacation
^^ entire strut has to come off the car.. that's what I did anyways.. strut, mount, spring.. all of it- I was able to move my wheel (still mounted on the car) up and down quite a distance lol
WILL NEVER FORGET
Old 08-14-2008, 03:26 PM   #14
make a how-to yo
Old 08-14-2008, 03:29 PM   #15
Midgear
on vacation
make a how-to yo
I'd much rather not pull it apart again.. if I dont have to-
mabey if I get some KYB struts i'll make a how to for it all over again
WILL NEVER FORGET
Old 08-14-2008, 03:31 PM   #16
don't need pictures just description of what to do in what order lol
don't you need a spring compressor or something?
Old 08-14-2008, 03:34 PM   #17
Midgear
on vacation
yes.. that's the biggest bitch of the entire job is compressing that spring to get it off the strut.. we almost launched a spring through my cousins WALL because one of the compressors slipped lol
WILL NEVER FORGET
Old 08-14-2008, 03:37 PM   #18
which is why i'm waiting to spend $200 on having it pro-installed
Old 08-14-2008, 04:24 PM   #19
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
you're throwing $200 away then. just go to auto zone and barrow one of their spring compressors.
1) remove struts from car
2) put spring compressor on spring to keep spring de-energized.
3) remove nut that keeps top of strut and bearing plate assembled.
4) remove spring from strut and undo spring compressor
5) compress lowering spring and place on strut
6) attach bearing plate to top of strut with spring compressed on strut
7) remove spring compressor from spring
8) reinstall strut
9) send me $100
FrankTheTank is offline   Reply With Quote
Old 08-14-2008, 04:30 PM   #20
hmmm.
