Old 09-02-2008, 08:54 PM   #1
sandstoneolds20
sandstoneolds20 is an unknown quantity at this point
Send a message via MSN to sandstoneolds20
Transmission Problem
I had my transmission fluid changed a while back and now its doing something weird. When i put it in drive it takes a bit for the transmission to engage. I was told by a transmission guy that its some kind of pressure sensor doing it. Apparently they had problems with this on the Aleros. Anyone out there know anything about it?
sandstoneolds20 is offline   Reply With Quote
Old 09-02-2008, 08:57 PM   #2
i've never heard of it being a know problem on aleros. it could be the position sensor on top of the tranny tells it what gear to go into when you move the shifter, but that doesn't have anything to do with pressures. if there was a pressure sensor bad the tranny should revert to safe mode i would think and it would just always shift at max pres. between gears.
is it doin it every time? i now mine does it once and a while when the tranny is hot but not all the time.
Old 09-02-2008, 10:07 PM   #3
TheEdgeofSanity
TheEdgeofSanity's Avatar
mine does that...i've come to terms that its just something that I have to live with and I always allow time to completely stop between shifting and let it do its thing.
2000 Chevrolet Malibu LS
Old 09-03-2008, 08:09 PM   #4
sandstoneolds20
The funny thing is it only does it in forward gears. I don't understand it cuz its never done this before and it started doing this like 2 months after I had the transmission flushed. The fluid is okay cuz i've had it checked at a shop and i checked it myself. Just pisses me off that it wants to do this.
Old 09-03-2008, 08:47 PM   #5
CactusWill
Could just be that your fluid is low.
Old 09-03-2008, 10:12 PM   #6
super white alero1
Trying to get it together
super white alero1's Avatar
How did they check the fill level? They need a tool, or must know the procedure. You have a sealed tranny so they might have drained and never filled to the proper level.
MODS:???
Old 05-19-2009, 12:00 AM   #7
gavin
gavin is on a distinguished road
My tranny seems to be jerking, like a stutter from 1st gear to 2nd..............any thoughts??
gavin is offline   Reply With Quote
Old 05-19-2009, 12:07 AM   #8
gavin
Its a auto...
