Old 10-18-2008, 02:22 PM   #1
jcoogs
jcoogs is on a distinguished road
Car won't start
I have just replaced my starter, alternator and battery, but my car still won't start. It clicks when I turn the key, and I have full power to the radio, wipers, etc., but it just won't start. I own a multitester, but I'll be darned if I know how to use it. Any ideas on the problem or instructions on how to test for it?
jcoogs is offline   Reply With Quote
Old 10-18-2008, 02:47 PM   #2
Is the security light on? Look at your gauge cluster.... Could also be a fuel filter or the pump.
Old 10-18-2008, 07:02 PM   #3
Listen for the buzz from the pump.
Old 10-18-2008, 07:06 PM   #4
Midgear
on vacation
if your security light is flashing.. you need to leave your car in the ON position for 10 - 11 minutes or untill it stops flashing, this resets your security and the car will start- or should.
WILL NEVER FORGET
Old 10-18-2008, 07:07 PM   #5
he said it CLICKS, it does not crank....siezed?? busted timing chain?
Old 10-18-2008, 08:56 PM   #6
jcoogs
Well, when I just turn the key to ON, the security light (as well as the "service engine soon" light, battery light, and oil light) do stay on. Nothing is flashing though. I didn't think anything of it, since I have a new battery and have enough oil.
Old 10-18-2008, 08:56 PM   #7
jcoogs
Well, it clicks once when I try to start the ignition.
Old 10-18-2008, 09:01 PM   #8
Midgear
on vacation
good.. then its not your security. can you hear your fuel pump when you first turn your ignition on? when you START the car, it just clicks? it doesnt crank at all?
when you hear said CLICK, does everything keep power or does everything shut off?
WILL NEVER FORGET
Old 10-18-2008, 09:43 PM   #9
CactusWill
Definately an electrical issue.
Old 10-18-2008, 11:08 PM   #10
Yep.... LOL
Old 10-18-2008, 11:37 PM   #11
starter solinoid?
Old 10-19-2008, 01:40 AM   #12
jcoogs
Yes, I can hear the fuel pump when I try to start the car. Yes, it just clicks once when I turn the key. It doesn't crank. I don't lose any power when I try to start it. All the power to the radio, lights, etc., is fine.
Old 10-19-2008, 02:11 AM   #13
Midgear
on vacation
Originally Posted by jayson_waltz View Post
starter solinoid?
he just replaced his starter lol.. check the wiring to your starter and make sure its fully connected- that's about the only idea I can come up with.
WILL NEVER FORGET
Old 10-19-2008, 07:05 PM   #14
jwateland
jwateland is on a distinguished road
check your wiring circuit for your starting system. haynes and other such manual will have it. it is problaly something in the wiring or the connections in any part of the circuit. forst work from the starter and starter motor. you'll need a fluke 87 meter which is a multimeter to do it right but those run pretty expensive. so learn about your meter and test the circuit.
jwateland is offline   Reply With Quote
Old 10-19-2008, 08:31 PM   #15
zzyzzx
zzyzzx's Avatar
Where did you get the replacement parts?
I'm guessing that you bought them at Autozone, Pep Boys, or some other place that sells mostly defective parts.
Old 10-19-2008, 08:36 PM   #16
Old 10-19-2008, 08:57 PM   #17
itsbmw
Does it start then stop running after a few seconds? If so it's the BCM, your fuxed if it is.
Old 10-19-2008, 09:22 PM   #18
GTFO AIM FOOL!
Old 10-20-2008, 10:35 AM   #19
jcoogs
I do buy from Autozone, but I got the starter from the "local guy" . That turned out to be the problem. I repaced the starter last night- again- and it started right up. However, now the battery light is lit on the dashboard and the wipers run rather slow.
Old 10-20-2008, 10:56 PM   #20
jwateland
like i said you have to find the pin point problem in the circuit. usually problems that bounce around like this is caused by a problem within the circuit. being wires or connections
