Old 11-03-2008, 12:57 PM   #1
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
trouble removing the front brake
are the 13mm bolts reverse threaded, or am I just not trying hard enough? seems like all these bolts on my car are way over-tightened.
BTW: Trying to replace 2 studs, because they broke off along with the lugnuts while I was driving a few days ago...been driving my grandma's Charger ever since. lol
Old 11-03-2008, 01:02 PM   #2
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Should be normal threaded, GM likes to use Loctite. Get a breaker bar or a metal tube you can slip over your wrench. If memory serves me right you can if on the drivers side lay on the ground and pull down which should be loose and on the passenger side you should have to pull up or you could lay on the ground and push up like doing a bench press.
Old 11-03-2008, 01:31 PM   #3
AlbinoMonkeyRat
Let's Play Army!
the way you describe is reverse threaded. but either way...the top bolt isn't budging, haven't tried the bottom yet.
Old 11-03-2008, 02:36 PM   #4
Righty Tighty, Lefty Loosey
Old 11-03-2008, 03:23 PM   #5
mine are all normal... no reverse threading here. i think your just reverse loosening them, hence why they won't come off.
Old 11-03-2008, 03:26 PM   #6
use a breaker bar. Those are on there tight because the brakes are the most important part of the car! Give it some muscle and it will come loose
Old 11-03-2008, 03:33 PM   #7
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
that made me chuckle pretty good.
FrankTheTank is offline   Reply With Quote
Old 11-03-2008, 04:58 PM   #8
Reverse way the lugnuts go on the car, since the bolts are behind the caliper. If they were reversed threaded, you would have gotten them off
Old 11-03-2008, 05:31 PM   #9
DOHC_tuner
DOHC_tuner's Avatar
I've done them a few times....and they are just really tight!
Old 11-03-2008, 05:41 PM   #10
Justin081
Justin081's Avatar
Justin081 is on a distinguished road
Send a message via AIM to Justin081
i just slipped a big metal pipe over the end of my ratchet and they came right off. there was no way i was budging them without the pipe.
http://www.fquick.com/Justin081
Justin081 is offline   Reply With Quote
Old 11-03-2008, 07:57 PM   #11
AlbinoMonkeyRat
Let's Play Army!
lol well, I know what I have to do now....
Old 11-04-2008, 08:27 AM   #12
CactusWill
We think you're a wimp, thats all. Put some muscle into it, you whiney little beotch
Old 11-04-2008, 12:19 PM   #13
zzyzzx
zzyzzx's Avatar
I use a breaker bar. Specifically this one:
http://www.harborfreight.com/cpi/cta...emnumber=30395
1/2" Drive 25" Breaker Bar
Get the extra torque you need to break loose stubborn nuts and bolts with this breaker bar
Strong chrome vanadium steel construction gives you the edge on tough jobs
Drive swivels 180° for the best angle on the work
Shipping weight: 3 lbs.
ITEM 30395-0VGA $12.99
Except I got it for $10 on sale.
Old 11-04-2008, 12:30 PM   #14
i use a nice long steel pipe
worked nicely for my brakes that didn't seem like they could ever come off
Old 11-04-2008, 12:33 PM   #15
i think i remember tapping mine free with a hammer, but after that i put a little anti-seize on them, so i don't have to kill myself getting them off again.
Old 11-04-2008, 03:47 PM   #16
Alerosaint
Gone but not forgotten
Alerosaint's Avatar
Alerosaint is on a distinguished road
Send a message via AIM to Alerosaint Send a message via Yahoo to Alerosaint
elbow grease son!
Alerosaint is offline   Reply With Quote
Old 11-04-2008, 06:28 PM   #17
AlbinoMonkeyRat
Let's Play Army!
got it off...turned out I was turning the wrong way to correct and paraphrase VTold's: bench press the driver side, pull it down on the passenger side.
and yes, liquid wrench did help.
Old 11-04-2008, 06:32 PM   #18
Midgear
on vacation
for the love of all that is holy.. make sure you put them back on SNUG.
my driver side caliper bolt (the bottom one) fell off while i was going down the highway- thought I ran over a rock.. and normally you dont use brakes while just cruisin along on an open road, so I didn't know it untill a traffic signal came up.. I hit the brakes and this wretched grinding noise filled the interior of the car.. scared the living crap out of me- babied it home and noticed my caliper was literally falling off O_o
WILL NEVER FORGET
Old 11-04-2008, 06:33 PM   #19
I CALLED IT!
Old 11-05-2008, 01:07 PM   #20
AlbinoMonkeyRat
Let's Play Army!
call this: I accidentally tightened the brake line bolt and the head broke off. (this morning before I had a lot of light, so I was just feeling around) and now I'm letting my brake fluid drip into a cup so I can take the caliper back off again to fix it.
