Old 11-25-2008, 09:53 PM   #1
bkathsalero
bkathsalero's Avatar
bkathsalero is on a distinguished road
Send a message via MSN to bkathsalero
l67 injector swap
NEED SOME HELP
anyone else on here do this b4?
the trouble im having is that i just got l67 (3800) injectors. these new injectors are obviously shorter than my stock injectors.. wot-tech has the brackets for l67 injectors.. but i dont c the point beacuse if i set the fuel rail on with no brackets attached the rail hits the lower intake ports and wont allow the injector to snug in either top or bottom holes (will snug in one but not the other) on the rail theres obvious cut outs to allow the rail to fit over the lower intake with the stock brackets.. but not deep enough now.. so i was thinking of grinding up to the line on the rail.. (obvious line its a ledge) but im not sure if that will give me clearence.. but now im just babbling.. anyone on here know what im talking about, or know how to help
dont know if its hard or if im just to stupid to figure a way around it..
and i couldnt find this with the search got a post from 10/19/08 under n/a upgrades witch didnt show any info pertaning on 1st page besides some l67 injectors for sale
(pics 1) L67 injectors (left) stock (right)
(pic 2) injectors commpared and see slots for lower intake
(pic 3) how i got the injectors from my co worker
bkathsalero is offline   Reply With Quote
Old 11-25-2008, 10:02 PM   #2
what mods do you have to think you need 3800 injectors?
Old 11-25-2008, 11:17 PM   #3
bkathsalero
wha do u mean by that
Old 11-25-2008, 11:58 PM   #4
i mean what mods do you have, i can tell you wether you are wasting your time with bigger injectors or not.....
Old 11-26-2008, 08:05 AM   #5
bkathsalero
cai, p/p 3.5 upper & lower, headers, msd coils, pulstars currently
by summer of 09
strip heads
lopey cam
75 shot (in progress)
65mm tb
spacer
Old 11-26-2008, 09:18 AM   #6
eh you are borderline for injector swap with those mods, i forgot what the GP injectors are i think like 32 or 36lb injectors, not sure on the fitment off hand, but i do know that trailblazer injectors are 28lb injectors and swap right in with no fussing.....BTW stock injectors are i think 17lbs, so long since i had stock injectors - ugh.....
Old 11-26-2008, 10:01 AM   #7
bkathsalero
What injectors are u running in ur alero
And the ones im running i believe are 33lb
Old 11-26-2008, 11:49 AM   #8
22 is the stock injector size.
I was thinking about going to the Evnoy injectors, but my mods don't support that. The car will waste gas. Envoy's are 28's
Old 11-26-2008, 12:05 PM   #9
bkathsalero
yes 22 is stock but im almost positive l67 is 33lb
Old 11-27-2008, 08:02 PM   #10
WhiteV6
Wide Open Throttle
WhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond repute
You don't waste gas by going to larger injectors unless the min pulse duty cycle is still too much fuel. 28# and even 33# is not too large for the stock ECM to be tuned, even on a stock motor.
Ben
WOT-Tech.com
60DegreeV6.com
WhiteV6 is offline   Reply With Quote
Old 11-30-2008, 04:00 PM   #11
xtremegagt00
xtremegagt00's Avatar
xtremegagt00 is on a distinguished road
i think the l67 has 36 pounders?...i think ive read that somewhere...ive got zzp l67 42.5lb injectors on my 3400 grand am, and i didnt buy no bracket..just wired in the connectors and everything went together just fine...no leaks no fitment issues...
00 turbo'd gagt msd 8.5,tr-6 plugs,42.5lb inj,65mm t.b,p/u intake,p/l intake,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,pems,custom turbo y pipe,open 2.5 in. downpipe,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost..,
2.041 60',13.683 @ 100.34STOCK CAM,STOCK 103XXX BOTTOM END..
99 gtp 4in. speedbuilt F.W.I...180 stat
xtremegagt00 is offline   Reply With Quote
