01-19-2009, 05:19 PM
Replacing factory fog light bulbs
Does anyone have advice on how to change the foglight bulbs? I had my headlight out once and sort of saw a way to get to them but it seems pretty involved. Also since both my fog lights are cracked right through the middle is there anywhere to get a good pair of foglights that fit Alero's? Thanks
01-19-2009, 05:30 PM
Open your hood and remove the headlight, theres 2 black tabs you lift to pull the headlight out and disconnect the bulbs. Once you have the headlight out, you'll be able to reach down and remove the foglamp bulb.
01-19-2009, 05:37 PM
Thank you I kind of figured thats all I had to do but didn't want to end up biting off more then I can chew.
01-19-2009, 09:39 PM
If you need to remove the fog lights from the car, it is a lot easier to remove the front bumper. It gives you a lot of space to work with, and only takes approx. 1 hour to do so. I used installed a set of factory fog lights on a car that does not have them.
01-19-2009, 10:08 PM
you can prolly find oem fogs from someone parting out, or a junkyard or ebay.
02-03-2009, 11:14 AM
I was wondering if there are any HID for the factory fog lights?
Take Life's Curves Sideways, and Drift!
02-03-2009, 11:16 AM
Yes but I don't know if they come in the factory size. There are other bulbs that are not exactly the same yet still compatible, you could find out more at your local auto parts store they will be able to tell you.
02-03-2009, 11:28 AM
they told me i'd have to change the plug to change the bulb
02-03-2009, 11:35 AM
Not if the bulb is compatible. There is more than 1 size that fits.
02-03-2009, 11:52 AM
so other than the guy from the store, is ther a place i could find out?
02-03-2009, 12:18 PM
Check out the websites, autozone, advance, napa, and any other you know of.
02-03-2009, 12:41 PM
Female.
my boyfriend climbs under my car and has the fog light bulb out in about 5 seconds.
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
02-03-2009, 05:51 PM
X2 it takes more time to open the pack to get the bulbs out then it does to put them in. If it takes anyone over 3 minutes to but those bulbs in please back away from the vehicle and return your drivers license to the MVA, DMV......etc.....LOL
02-03-2009, 06:01 PM
LOL
I need HID or LED versions of the factory bulbs and i m good to go!
3 mins and i m done
02-03-2009, 06:11 PM
HID is better. LED light won't carry very far.
02-03-2009, 06:41 PM
yeah, i bought some LED foglight bulbs, i was a young retard, and they SUCKED
02-03-2009, 06:52 PM
You almost said that like it was past tense
02-03-2009, 08:59 PM
Yeah undo the 10mm bolts holding on the fender liner to get access to the fog light housing, then just twist and they drop out.
The size is 894, 893, and 880's both fit the housing, but the wattage is lower and the bulbs don't last that long
02-04-2009, 08:27 AM
So where can i buy these bulbs HID version
Canadian Tire???
BTW, if i switch to HID, do i have to change my cables?
02-04-2009, 08:58 AM
hey lonnie, your boyfriend climbs under your car for you, thats nice. lol...jk
