Old 06-12-2004, 04:59 PM   #1
Oldsmopimp
Thumbs up
Well guys...... I dunno what the hell the prollem is...
Ever since I installed Intrax and got new wheels the car pulled to the right.
This morning I brought it in for a 4-wheel allignment.
The toe-in was off, and everything else including camber(phew!) was apperantly ok.
The guy fixed everything and took it for a spin....he said it still pulled a little and he said its something with the tires.
The allignment didnt do crap for me except cost me 70.00.... issed:
I'm looking for any ideas or suggestions as to what is causing this problem, because I dont want to wear out my tires and its VERY annoying to drive.
-Pulls to right, VERY noticable at higher speeds(55mph)
-Sometimes steering wheel shakes, VERY noticable at higher speeds(55mph)
....Im stumped.....
I do have 4 1/2" bolt pattern wheels...but I also have hub-centric rings. I also doubt they are out of balance...but maybe one is??????
Any input would be much appreciated.... Thanks abunch
Old 06-12-2004, 05:31 PM   #2
dadirtybulldog
well, well.... someone with the same problem as me.... my car pulls extremely hard to the right and i have extreme shaking around 60-70 mph's, i also have aftermarket rims but i don't have hubcentric rings, my rims are the exact, exact same bolt size/pattern as the stock ones.... i've had this problem for quite awhile now... i've had one dealership and three different independent mech's look at it... this is what i've fixed/replaced/etc. : four tie rods, two wheeel/bearing hub assemblies, new tires, two alignment's by different shops, balanced and re-balanced.... nobody has been able to fix this problem for me... i'm afraid something could be wrong with my axle or something really serious like that... here's a link to a thread i posted-----> shaking!
Old 06-12-2004, 06:07 PM   #3
Grouch
stuck/dragging brake caliper? How are your brake pads wearing?
Old 06-12-2004, 09:56 PM   #4
Voodosoup
I've just recently developed the exact same problem.
I took a 100+ mile trip a couple weekends ago.
And on the interstate at 70+mph the car would go between periods of shaking and then it would stop for a while, then it would shake again. I also have the pulling to the right problem, it seems to be worse when it's shaking.
Old 06-13-2004, 03:14 PM   #5
Oldsmopimp
I replaced my front pads about a 4K ago or so.......Ill have to look a lil closer, Grouch may be right..... But like I said this only started after I put new springs(Intrax) and new wheels on the car. Ill check out the brakes..
Any other ideas??
Old 06-14-2004, 02:09 AM   #6
bnight04
bnight04's Avatar
bnight04 is an unknown quantity at this point
Send a message via AIM to bnight04
this could be really stupid but when my car did that it was just the tire pressure......... check it, if not then no harm done
2004 40th aniv. mustang
2006 kawasaki ninja
bnight04 is offline   Reply With Quote
Old 06-14-2004, 08:45 AM   #7
alero168
I Love Tiara!
alero168's Avatar
alero168 is an unknown quantity at this point
Send a message via AIM to alero168
have you checked your hubcentric rings? theyre pretty weak and may have been broken or just placed wrong.
alero168 is offline   Reply With Quote
Old 06-14-2004, 12:20 PM   #8
White_Alero
The pulling to the sides was happening to my car before i got it and at the dealer they put in a strut bearing i think and it has fixed the problem. But it still shakes at high speeds during the first 10 minutes or so of driving then it seems to smooth out.
Old 06-19-2004, 09:12 PM   #9
Oldsmopimp
well.....I rotated the tires today. Didnt help at all... issed:
Hubcentric rings are fine, brakes are fine, and tire pressure was same on all four tires. (i checked all those things) I'll take the tires in for re-balencing just to be sure
anyone else have any idea????????????
mfuller?? Hes a smart guy right?? help! lol!!!
Luckly I dont drive the car much so Im able to deal with it for the time being.
Old 06-20-2004, 12:26 AM   #10
wc_alero
Well I had the same problem and it was my steering rack leaking.
Old 06-20-2004, 09:53 PM   #11
I had the problem too
Had to have the hub replaced, worked for a bit, now same problem. I think my other hub is going too but after reading these posts I'm thinking the rack for me too.
I get a horrible creeking when I cut the wheel hard right but only below 10 MPH. Going to the dealer this week to find out
Old 06-20-2004, 10:30 PM   #12
Oldsmopimp
dood, I think u are the winner! I noticed fluid seapage around there.....Im gonna take it in and see what they say. Thanks!!!!
Reddog....I dont think its my hubs..from what I know a bad hub will whine and creak, I dont have any of those symptoms. although I know alot of alero guys have had bad hubs around this milage(40K) so those are prolly goin too!! lol,
thanks guys!!
Old 06-20-2004, 11:36 PM   #13
smokinAMD
My steering rack is going out too.
