Old 02-28-2009, 11:32 AM   #1
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Center Bore
ok i gave up and eff the search button on this one i tried
hub centric rings fix the center bore issue yes
but im seeing rims that list the size of the center bore such as 72 and 73 (if thats millimeters i dunno)
but what is the size of the center bore for the alero, itd be great to get a set and not eff with hub centric rings
Old 03-01-2009, 01:40 AM   #2
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
Old 03-01-2009, 01:48 AM   #3
center bore....are you talking about rim offset?
Old 03-01-2009, 02:19 AM   #4
yeah,
Old 03-01-2009, 02:19 AM   #5
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
no the hole in the center
Old 03-01-2009, 02:21 AM   #6
oh.... what??????
Old 03-01-2009, 02:24 AM   #7
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
omfg the hole in teh center, the part hubcentric rings r for, u know like the base it sits on, the size of the cut out for that, i dont want to get a rim with a bore to small, aka unusable
Old 03-01-2009, 02:38 AM   #8
dragon8807
dragon8807's Avatar
dragon8807 is on a distinguished road
Send a message via Yahoo to dragon8807
the hub size is 70.3mm
99 alero - totalled
96 impreza 5spd awd - sold
dragon8807 is offline   Reply With Quote
Old 03-01-2009, 09:33 AM   #9
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
thanks so these rims that are 72 and 73 will be great with rings much appriectiated, does anyone know whats the lowets offset possible by average state law for the alero, im thinking less offset will make the rim and tire stick out a bit from the tire wheel, a look ive always liked, but then you get in trouble with fender laws atleast with offroad trucks
Old 03-01-2009, 10:28 AM   #10
i don't know about state law, but my wheels are a 17x8 with +32 offset and they fit right at the edge of the fenders, to get the rears to match you either have to have a staggered fitment or some spacers in the rear
Old 03-02-2009, 06:54 PM   #11
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
what? why because of the drums, i dont get it how can they have differnt mess, when you rotate you wheels they sit the same, why would you need spacers to make the rrears right
Old 03-02-2009, 08:19 PM   #12
i mean to get the rear to come all the way out to the fender edge like the front does with a 8" wide, +32 offset wheel
Old 03-02-2009, 08:56 PM   #13
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
oh becuae the fenders wider, i think it just dawned on me what yoru saying
Old 03-02-2009, 10:41 PM   #14
Valley olds
Valley olds's Avatar
kwhauck: i don't know about state law, but my wheels are a 17x8 with +32 offset and they fit right at the edge of the fenders, to get the rears to match you either have to have a staggered fitment or some spacers in the rear
How thick would you suggest the spacers be?
Old 03-02-2009, 10:53 PM   #15
it depends on the offset of your wheels to begin with, and then you have to think about the extra stress you are putting on your wheel studs with spacers....
Old 03-02-2009, 10:56 PM   #16
Valley olds
kwhauck: it depends on the offset of your wheels to begin with, and then you have to think about the extra stress you are putting on your wheel studs with spacers....
So thicker spacers= more stress on the wheel studs?
Old 03-02-2009, 11:31 PM   #17
just a plain spacer like these
will put more stress because you move the wheel out and have less stud that the wheel is threaded onto. Bigger spacers like 1" up size have their own wheel lugs to help this problem, they are mostly used on 4x4 vehicles
Old 03-04-2009, 11:24 PM   #18
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
yeah.
Old 03-04-2009, 11:29 PM   #19
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
yeah.
oh yeah?
Misuseofyou is offline   Reply With Quote
Old 03-06-2009, 11:49 PM   #20
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
hey dont slap me im double checking info i think is worng
i thought spacers gave civics and s10s the weels that stuck out an inch or 2 from the well, another cook at work said that was just lowprofie tires i thought it was spacers i thouhg low profile just meant thint tires for big rims
