Old 03-01-2009, 04:31 PM   #1
shiny alero
shiny alero's Avatar
shiny alero is on a distinguished road
Send a message via AIM to shiny alero
how do i wire this?
im confuesed...dont make fun of me but how do i wire this...there is pos and neg terminals on both sides of the sub
shiny alero is offline   Reply With Quote
Old 03-01-2009, 04:40 PM   #2
dvc sub.
http://www.the12volt.com/caraudio/wo...igurations.asp
Old 03-01-2009, 07:03 PM   #3
itsbmw
just run another price of wire from that first wire you put on there to the other terminal. make sure you wire them properly for your amp.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Old 03-01-2009, 08:49 PM   #4
it depends on how many ohms u want it to show up as.
Old 03-02-2009, 08:52 AM   #5
surreal_awakening
surreal_awakening's Avatar
^^^ +1
Just saying to run a wire between the two is oversimplification. You need to see how many ohms your amp is rated for and determine the best method for wiring your DVC sub.
Old 03-02-2009, 02:46 PM   #6
itsbmw
Originally Posted by surreal_awakening View Post
^^^ +1
That is why I gave him the woofer wizard silly
Old 03-02-2009, 10:22 PM   #7
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
any one wanna lemme know what to do with the rem wire off the amp with out cyber slapping me
Old 03-03-2009, 06:04 AM   #8
itsbmw
remote wire from the amp goes to the remote wire on the back of the head unit, I think it is blue with a white stripe, just check to make sure. that is needed to turn on the amp.
Old 03-03-2009, 06:33 AM   #9
dhurst765
dhurst765's Avatar
dhurst765 is on a distinguished road
Or Wire Up A Switch
dhurst765 is offline   Reply With Quote
Old 03-03-2009, 07:00 PM   #10
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
r u shure, theres already the rca cables being run to the head, why would that wire be for that
Old 03-03-2009, 07:04 PM   #11
Valley olds
Valley olds's Avatar
AleroRacing: r u shure, theres already the rca cables being run to the head, why would that wire be for that
The remote wire is so the amp will not be on all the time. It will be on only when the stereo or car is on. RCA's are so the amp know what to play. If you didnt have rca's the amp wouldnt do anything because it would be receiving no signal as to what to play.
Old 03-03-2009, 07:10 PM   #12
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
man that sucks thats alotta exta wire, does taht need to be a certain guage or can i use a peice of cheapo wire if its for taht it doesnt need to be realy quality does it
Old 03-03-2009, 07:12 PM   #13
it can be rather small. its only carrying like 300ma. 18-20ga should work just fine.
Old 03-03-2009, 07:12 PM   #14
Valley olds
^ beat me to it
Old 03-04-2009, 01:04 PM   #15
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
If I take that rem wire a put a swith to it I can easily and safely turn the amp on and off right? I was gonna try to do in on the power source but I heard that was a bad idean if you have a capacitor
Old 03-04-2009, 01:07 PM   #16
lol
DO NOT SWITCH THE MAIN POWER WIRE.
But you can put a switch on the remote wire.
Old 03-04-2009, 02:33 PM   #17
Dhoyle
Si vis pacem, para bellum
Dhoyle's Avatar
Dhoyle is on a distinguished road
lols, i was lazy and since it was my first time, i bought the 79$ one from walmart that came with everything i needed, 5 and 6 ga wire, capacitor, RCA, and t really tiny remote wire
After you party naked.... always go to the nearest clinc afterwords....
Dhoyle is offline   Reply With Quote
Old 03-04-2009, 10:54 PM   #18
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i know the kit your talking about, its a bit of a rip,
Old 03-04-2009, 10:57 PM   #19
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
an audio professional told me i could switch the power cable i was a little iffy about it, promised myself to get a switch with RUBBER round the switch, but i heard that discharging a capacitor was dangerous less done right so i gave it up,
the switch will be used to turn off the amp and sub when around GFs parents
Old 03-04-2009, 11:22 PM   #20
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
Your head unit should have the ability to turn off your subs. No offense but you shouldn't be screwing around with electricity.
Misuseofyou is offline   Reply With Quote
