Old 03-05-2009, 04:24 PM   #1
alero_bmxer
alero_bmxer's Avatar
amp shutting off?
so i have 2 10" pioneers and a 600 watt sony amp and when i bridge the subs and turn my radio up over like 20 the amp shuts off and the protect light comes on but i can turn my radio off and then back on and they will work again. any possible ideas as to why??
Old 03-05-2009, 04:26 PM   #2
Improper ohm load, improper gain settings, bad ground, not enough voltage.
Take your pick. Start with the first possibility and work from there.
Old 03-05-2009, 04:27 PM   #3
alero_bmxer
how can i figure the right ohm load?
Old 03-07-2009, 12:27 AM   #4
you would need the specs for your amp and your speakers.
