Old 03-07-2009, 03:53 PM   #1
CactusWill
Best Place To Go Through Firewall?
Where is the best place to put wiring through the firewall safely, doing the least possible amount of work? I need to get it through on the drivers side if poss., from drivers side area to underhood fuse/relay box area.
Old 03-07-2009, 04:07 PM   #2
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
People will say the grommet all your other wiring goes through, but I didn't use that. I went through the fender then used the grommet in the door. Haven't had any problems with it.
Misuseofyou is offline   Reply With Quote
Old 03-07-2009, 04:20 PM   #3
Haha the fender way is the cheap way. That's what I've done too.
Old 03-07-2009, 04:27 PM   #4
CactusWill
Ahh ok. So kind of like, behind the wheel well and then you can feed it through to inside of the door sill?
Old 03-07-2009, 06:02 PM   #5
Steering shaft grommet.
All my wires run though it, very easy, but you'll need a coat hanger to bring the wires up
Nice clean install
Old 03-07-2009, 06:04 PM   #6
behind the brake pedal. pull the insulation back, and just above it there is a big gray grommet. push a hole in that, and snake your wire through. it'll come out just below the fuse box in the engine.
don't go through the fender. thats for wussies who can't do it the right way.
Old 03-07-2009, 06:11 PM   #7
^^ Looks like shit too ^^
You don't have to punch a hole in the grommet, just open it up and put it back
Old 03-07-2009, 07:07 PM   #8
bonez1203
bonez1203's Avatar
bonez1203 is on a distinguished road
drill a hole in the firewall and use
http://www.parts-express.com/pe/show...number=263-635
its the cleanest safest way to go.
bonez1203 is offline   Reply With Quote
Old 03-07-2009, 07:16 PM   #9
I'm going to redo all my wiring before ASS. Right now it's a big mess in the fuse panel, console, and above the driver side footwell.
